Speaker cable
I need to buy some cheap speaker cable (a dollar a foot or less) to connect my Technics SA-EX140 receiver (100 wpc) to the passive subwoofer from a Bose Acoutimass 3 Series III speaker system (found for 3 dollars at a garage sale). Both have spring clips.
I was thinking I would get some 12 or 14 gauge car stereo speaker cable. If anyone has any suggestions for size or brand of speaker cable that is $1/foot or less, I would appreciate it.
Post edited by brittan_farmer on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2002
    Lowes or Home Depot 14awg, should run you $.20/ft or so, and will be more than sufficient for your application.
    Cheers,
    Russ
  • phuz
    phuz Posts: 2,372
    edited July 2002
    Cheers,
    Russ
    :lol::lol::lol::lol:
  • brittan_farmer
    brittan_farmer Posts: 12
    edited July 2002
    From the sub to my pair of r10s I have some pure links micro reference cable by esoteric audio, so I thought I might get some street wires cable, which is made by esoteric. Either that or some monster cable XP cable. I will need a pair of 6-foot lengths. Right now I'm using 18 gauge wire that probably came with the Bose system.
  • RuSsMaN
    edited July 2002
    Sounds like you already know what you want then.
  • brittan_farmer
    edited July 2002
    I just want to know if anyone knows of better cable than what I have in mind.
  • RuSsMaN
    edited July 2002
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1367438783
    There ya go, more than enough 'beef' for your application, and factory terminated with pins....
    Cheers,
    Russ
