Intensive Care For 300 Bucks!!
LiquidSound
LiquidSound Posts: 1,261
edited April 2024 in Clubhouse Archives
People are gonna get hurt. Video of injuries will be on the net soon, I'm sure.
Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
  • Jstas
    Jstas Posts: 14,997
    edited November 2005
    If a helmet is a required fashion accessory for a glorified pogo stick then I think I don't want to be on said pogo stick. Add to that the fact that the Owner's manual says that "Once you master the Flybar 1200, it's possible to bounce so high that the top of your head will be 10-to-12 feet in the air. Even novices, however, should check for overhead clearances all around the field of action."
    Also, of special note, you, not the factory or the dealer or whatever, YOU need to adjust it to fit your skill level and weight before use.
    no sir, this does not bode well for our caped crusader!
    Expert Moron Extraordinaire
  • PolkThug
    PolkThug Posts: 7,532
    Just a matter of time before somebody's little sister gets impaled...
  • steveinaz
    steveinaz Posts: 19,546
    I'm already searching "Stupid Videos"...LOL
