Intensive Care For 300 Bucks!!
LiquidSound
People are gonna get hurt. Video of injuries will be on the net soon, I'm sure.
Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
Receiver - VSX-54TX
Mains - Csi40's
If a helmet is a required fashion accessory for a glorified pogo stick then I think I don't want to be on said pogo stick. Add to that the fact that the Owner's manual says that "Once you master the Flybar 1200, it's possible to bounce so high that the top of your head will be 10-to-12 feet in the air. Even novices, however, should check for overhead clearances all around the field of action."
Also, of special note, you, not the factory or the dealer or whatever, YOU need to adjust it to fit your skill level and weight before use.
no sir, this does not bode well for our caped crusader!Expert Moron Extraordinaire
Just a matter of time before somebody's little sister gets impaled...
I'm already searching "Stupid Videos"...LOLSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
