SVS speakers (not just subs) almost here.
McLoki
McLoki Posts: 5,231
edited November 2005 in Speakers
Read about it here.
Preorders starting mid to late November - shipping in time for Christmas.
5.1 system (including their pb-10isd) about $1,000.
Color - anything you want as long as its black.
Made in China.
Here are the specs :
Specifications:
Model Name SBS-01
Configuration Bookshelf
Design Sealed
Dimensions (Grills included) 12" x 7" x 9.5"
Weight 11lbs (5kg)
Drivers Tweeter (1) 1" (25mm) ClearPoly™ diaphragm
Woofer (1) 5.25" (133mm) polypro. cone
Frequency Response (Anechoic) 75Hz - 20kHz ± 3dB
Nominal Impedance 8W
Sensitivity 85dB
Power Handling 20W - 120W
Magnetically Shielded? Yes
Mounting Options Threaded inserts for wall bracket
Single keyhole for wall mount
Surface/shelf mount
Enclosure Material MDF w/ internal bracing
Finish Light textured black vinyl
Specifications:
Model Name SCS-01
Configuration Center Channel
Design Sealed
Dimensions (Grills included) 7" x 20" x 8.5"
Weight 19lbs (8.6kg)
Woofer (2) 5.25" (133mm) polypro. cone
Sensitivity 87dB
Mounting Options Threaded inserts for wall bracket (2 set)
Single keyhole for wall mount (2 sets)
Surface/shelf mount
TILT-Base™ platform (removable)
Michael
Post edited by McLoki on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited October 2005
    I saw this earlier today...Looks like they are shooting somewhere between the Hsu and ELT packages. I wish them well.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • jwienand
    jwienand Posts: 80
    edited October 2005
    I can't wait to get one of their subs, but I think I'll keep the others Polk :D
  • marcpam
    marcpam Posts: 228
    edited October 2005
    Their 5.1 system does not impress me at all. Go to their website and you can see a sketch/specs on them. I would stick to their subs and leave the other speakers to someone who has been in the mix for awhile.
  • Ron Temple
    edited October 2005
    They've been working on these for quite awhile. I wouldn't be shocked if they are surprisingly good, notwithstanding the specs.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • McLoki
    McLoki Posts: 5,231
    edited October 2005
    Actually I thought the sketches looked alot like my LSi7 / LSiC setup. Looks like a great system for an initial upgrade from your typical HTiB.
    Then again - even though it looks similar, I think I will stick with my LSi setup.. :D:D
    Michael
    BTW - anyone else notice that those speakers are not that efficient. You will need quite a bit of power behind them to get an decent volume levels out of them......
  • PolknPepsi
    PolknPepsi Posts: 781
    edited October 2005
    There was a thread at the Klipsch forum with about 6 replies regarding the svs speakers and it got locked.....guess they dont want to hear about or are very afraid of the competition....lol.
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • schwarcw
    schwarcw Posts: 7,360
    edited October 2005
    I saw them setting these up as a demo unit at their factory in Youngstown, Ohio. They didn't say much about it. They were calibrating their HT system.
    Carl
  • PolknPepsi
    edited October 2005
    I wonder what speakers they are comparable to from another brand?
  • gregure
    gregure Posts: 871
    edited October 2005
    I'm not a fan of sub/sat systems with my preponderance of music listening, but they can work for many people. Those may be decent speakers, but the I noticed they don't have very good sensitivity ratings for 8 Ohm speakers.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • LiquidSound
    LiquidSound Posts: 1,261
    edited October 2005
    They've got pics up now. http://svsubwoofers.com/news.htm
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
    "If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
  • BobMcG
    BobMcG Posts: 1,585
    edited October 2005
    I wish them all the luck.... they'll need it. The entry level HT market has no lack of competition.
    And just off the cuff:
    Entry level speakers with quite likely lots of entry level 5.1 all in one HT recvrs pushing them? Can you say piss poor sens?
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited October 2005
    If their speakers are anything like their subs they should be awesome.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Ron Temple
    edited October 2005
    Here's a guy that got to try them...I volunteered, but there just aren't enough units to go around :(
    http://www.avsforum.com/avs-vb/showthread.php?t=597107
    Looks pretty interesting...
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • LiquidSound
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
  • Airplay355
    Airplay355 Posts: 4,298
    I bet they will be much better then similarly priced HTIBs. $999 for a 7.1 channel system doesn't sound horrible to me.
  • Ron Temple
    I expect that they are aimed straight at Ascend 170s and Rocket ELTs. If they don't perform as well or better, I'd be surprised :) .
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Whadyasay
    Whadyasay Posts: 300
    Not the prettiest things I've seen, but I applaud the effort.
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
    heiney9 Posts: 25,630
    I'm sure for $1000 for an entire HT set-up they will perform.....well as good as can be expected. They certainly aren't anything ground-breaking. Look at those tweets. WOW, is that dome recessed. Can anyone say Beaming. How can you get a consistent dispersion pattern if the dome is so recessed? That's the only thing that jumps out at me as being peculiar. They are entering a stiff market at that price point. Hopefully they will perform well and live up to the reputation the subs have.
    Also, my brother has 3 systems in his house. HT, 2-CH and computer. For his HT he has an Energy HT set-up very similiar to new SVS HT config. He bought these as a package and they sound excellent and are perfect for HT. The Energy's are smaller and more elegant looking than the SVS HT, which look rather sterile to me. I'm sure the SVS sub in the new HT system's is better than the Energy sub. But overall I like the looks of the Energy system better.
    My point is that there is a lot of competition for HT packages, beyond the std. HTiB crap. It would really be interesting to see how the SVS HT set-up compares to the Energy HT set-up.
  • PolkThug
    PolkThug Posts: 7,532
    spec correction:
    "Frequency Response (Anechoic) 68Hz - 20kHz ± 3dB"
