New SvS pb-10 Missing A LOT of bass
Jer_ry
I recently got my pb-10 in about a week ago and have been testing ever since. After all the hype i'm not to pleased with it's performance. It performs awesome on SOME thuds for example in finding nemo when the shark hits the ship and explosions like in Hitch hikers guide when the red escape pod lands. But THATS IT. It's completely not present in some explosions and for example the car crash on my old sub produced bass on the same movie. And on the first Xmen on chapter 14 when they are in the train station when cyclops blows a hole in the roof on my old sub there was a big swing in bass it does a hit then dives down. The svs did not come close to picking that up you cannot hear it AT ALL as if there is nothing there is the first place. I have found this missing bass in a lot of other stuff too. Dinosaur growls comes only from my speakers with no bass presence.
Post edited by Jer_ry on
hmmm....strange; what equipment are you using with it? How do you have your crossover setting?_________________________________________________
HTrookie wrote:hmmm....strange; what equipment are you using with it? How do you have your crossover setting?
Hmm you may have told me my problem. I'm using a yamaha htr-5250. No crossover. -
It could be your setup, sounds like maybe you have a gap between the sub and speakers ranges.
It could also be that the old sub had huge spikes in the midbass range that you became accustomed to and the SVS is just flatter. If this is the case, you have to overcome the addiction to "boom". How does it sound when used for music?HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Go through your chain and figure out where the low bass is being filtered out at. The SVS is more than capable of producing the lowest lows, especially in a room.
Did you set your speakers to "small" on the AVR, so bass below the crossover point goes to the sub? (I'm guessing this is your problem) -
music is very low bass thats it. Yes there is a big gap
Jerry,
Tell us how you have it hooked up. are you using a cable from the subwoofer output or are you running your main speaker lines through the sub.
Edit:There may be a variable setting in your receiver, but I do recall some Yamahas have set points.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Well, I am not familiar with that Yamaha... but if it's a receiver I am sure it should have as part of the speaker configuration a setting for the frequency at which bass should go to the subwoofer...doesn't it?_________________________________________________
I don't believe the PB10 has a low pass filter, but allows the receiver to set the crossover. Sounds like a receiver issue, but I would think there is at least a fixed crossover (probably 100 or 90) in the settings menus.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote:I don't believe the PB10 has a low pass filter, but allows the receiver to set the crossover. Sounds like a receiver issue, but I would think there is at least a fixed crossover (probably 100 or 90) in the settings menus.
It doesn't; the PB10 only has a line input._________________________________________________
Be sure
You have the subwoofer hooked up to the Yamaha rec. "SUB OUT"
You have set the receiver to subwoofer "yes"
On your Yamaha you can choose for the bass and LFE information to be routed SW/MAIN/BOTH that means bass is routed to your subwoofer or front speakers or both. Depending on your main (front) speakers, this is usually set to SW, directing the bass to your subwoofer.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
What are your mains? Do you have satelittes?
Did your old subwoofer have a variable crossover? Where did you set it?
What is the internal crossover in your receiver? Does it have one?
Sounds like the SVS is crossed WAY below what your old subwoofer and isnt picking up NEAR the information it is supposed to.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My sides are satelittes soon to be rti6's i have the sub on the "Sub Out" on my reciever i'm trying to find the crossover on the reciever if it has one what would it be called Freq? I think my old sub (psw202) had a crossover on it. I'm also trying to see if all my speakers are set to small i'm pretty sure they are...kinda hard to do now that my remote just stopped freakin working...jesus
Hmmm...the good news for you? You are forced to upgrade
ok my center was, for some reason, set to LRG i reset that to small i think i found the crossover. one says D.D LFE ( I assume means Dolby Digital) and the other DTS LFE. Now the highest it goes is 0 and the lowest is -20 which way fills in more of that missing gap?
higher the number, higher the output. higher to the positive side, anyway. but this is just the output and not a crossover. just turn it up by ear and leave alone when satisfied.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
I have the Yamaha 5240 so my receiver is similar. The crossover is fixed at 90hz. Set your receiver up as follows:
Set all speakers to small
set sub to yes/on
direct LFE/bass to Sub only
turn the dynamic range to STD or MAX, your choice.
set the LFE output to -5, the DTS and Dolby Digital LFE levels to 0.
Then adjust the subs volume by ear using the volume dial on the SVS.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I must say changing that center from lrg to small made a difference already. I thought i had messed with all the setting which i did but i didnt even relize it was set to lrg. If i do upgrade my reciever which route should i go?
i like my harman/kardon. you can pick up a lower end model for cheaper and even refurb on ebay with fac. warranty. or go with onkyo. some have gone with outlaw. everyone else can throw in some model numbers if they so choose.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
How much do you want to spend?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
wow....i put music on and it's a HUGE difference still kinda low volume thats what the problem was...center set wrong
what is d-range?
not to sound cheap but the lowest possible.... -
Jer_ry wrote:what is d-range?
I would say that it is a setting for reducing the dynamic range (volume variance) for late night listening. Great for DVDs after hours.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
