Question on SVS subs
dpowell
SVS has recommended the PB12-Plus/2 for my HT system.
I was wondering if anyone here who owns an SVS sub has utilized the Parametric Equalizer feature. ("The PEQ will allow you to tame the worst room resonance (a peak in the bass response caused by room modal patterns.")
If I order in basic black, it doesn't come with that feature. The wood grained models do come with it but cost a couple hundred more. SVS support said that unless the room had numerous openings that could lead to room resonance, that it probably wasn't necessary to have but I'm wondering for down the road if I might need it.
Suggestions?
Suggestions?
Post edited by dpowell on
Color choice eliminates the EQ? Strange marketing plan.....HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
NO, color adds the eq.. ie: higher end model has better features..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
For the PB12-Plus/2 model, basic black has no PEQ at $1,199. Same model with wood grain texture or piano gloss black has the PEQ at $1,399.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Myself, I would buy the color I preferred, then purchase a Behringer Feedback Destroyer ($100) if needed. I gives you way more flexible parametric points. I think it has 12 per channel a little overkill for HT, but it is a cool piece.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote:Myself, I would buy the color I preferred, then purchase a Behringer Feedback Destroyer ($100) if needed. I gives you way more flexible parametric points. I think it has 12 per channel a little overkill for HT, but it is a cool piece.
100% agreed. I have one myself and an svs sub. -
Personally,
the peq didn't play a major part on my purchase. I also have the textured black and I love it. -
agreed.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
I have a BFD and SVS as well. While an excellent marketing plan and perhaps a decent improvement - I would think you will want more than just one eq channel to control your bass. (if you are going to try at all) Even if it had a PEQ I would still get a FeedBack destroyer for $100 to act as an equalizer.
Long story short - get the color you want and don't sweat the EQ.
My Maple PB12 plus/2 has PEQ which I don't use since I have a pretty smooth house curve as is.
Good to know. I believe a black PB12-Plus/2 is in my future but need to save a few more $$.____________________________________________________________
I've had a PB-2/Plus (no PEQ) since last year; it eventually became the SVS PB-12 Plus/2. An extremely nice piece of gear; well-worth the money!
A comment on your eye-candy concerns: If you find that you're not satisfied with black it would not be too difficult to dress-it-up with a fabric/color of your choice. I think that someone with basic sewing machine skills could easily do this; it would probably require only four or five yards of material to cover four sides of the sub (the rear, for connectors, etc would remain uncovered). You could easily disguise this sub and have it look like an end-table or whatever. Put a lamp or something else on top and you'd never know its real function (especially if it's properly calibrated).
I have a pet 800 lb gorilla :eek: so his home is sitting on my 140 lb SVS!
-GeorgeM -
-GeorgeM
....please, elaborate..........
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
GeorgeM wrote:If you find that you're not satisfied with black it would not be too difficult to dress-it-up with a fabric/color of your choice.
-GeorgeM
Great idea. Can't believe I didn't think of that before. I can have my wife sew a quilt for it. Maybe even cover all my speakers. It'll save the nice wood grain texture.
Is this kind of along the lines of what you were thinking?
BIZILL: Well my 795 lb gorilla (he's been on a diet
) is actually one of my "Imaginary Heroes" (great movie on DVD if you have not seen it...)that occasionally takes advantage of the solid construction of the SVS and rests his posterior there to absorb the soothing 15 Hz freqs; it keeps his temperament in-check
dpowell: Great choice of fabrics!!! Dazzling!!! You'll have to furnish sunglasses to all visitors; no snoozing in this environment...
-GeorgeM -
GeorgeM wrote:BIZILL: Well my 795 lb gorilla (he's been on a diet
-GeorgeM
:eek: :eek: :eek: :eek: :eek:
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
dpowell, that is some funny shi*, i don't care who you are, that is some funny shi*!!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
