LSi15 posts - plug in top or bottom?
derdock
Does it matter whether I plug my speaker wire into the top set of holes or the bottom set of holes....or does the metal jumper make that irrelevant?
Thanks!
Thanks!
Post edited by derdock on
the metal jumper makes that irrelevant...
Thanks for the quick reply
DittoDan
you would use both for bi-ampingSuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
You have to use both for bi amping. Your connecting 2 power amps to a single speaker. At this time you would remove the jumpers. Also for bi wiring.
DanDan
