upgrades......
TroyD
Just curious what folks think is the most signicant improvement that one can make in his rig. For example, what upgrade, in general do you think gives you the most bang for your buck? Say you could upgrade only one thing in your rig what would it be?
Just curious what others out there are thinking......
BDT
BDT
Post edited by TroyD on
I can hear Mantis now, in a Beavis voice 'WIRE! WIRE! WIRE!'....
As far as the topic goes, I am looking at good high-mass, fillable stands, I'm fairly content with the rig for now....
Cheers,
Russman,
Yes Wire would be on top of my list as I have found it can make a big big difference.
TroyD,
I think reviewing the entire system owned and finding the weakest link would be what I would upgrade.
Like check this out.If you have speakers that are great,good power amp,preamp,All Interconnects are of sound quality(Monster just for Russman),and you still have an older cd player with built in dac's or a transport with older external dac's that could be Improved,I would go there.Find a better cd player and or Dac's of better quality.
I see things this way.What is the worst part of my system and how can I make it better.
Amps is another great upgrade.Finding a better amp can make a real sonic dynamic difference.If your current amp lacks drive.
In the end If all else is tight,changing out speaker wire or Interconnects can make the biggest inprovement.
Last but not even close to least............CLEAN POWER.20 amp to the rig.On it's own circuit.Then a voltage stablizer.Dan
what I'm shooting for here guys, is what is the one thing in your rig that you want to upgrade. For me it's my rack. I'm just looking to see what the rest of the folks are pondering, gear-wise. Encourage a little forum participation, you know?
Everyone's case is different but, ok , all things being equal in this vein, I think the biggest upgrade in general is switching from a receiver to separates. In general I think that provides the most bang for the buck improvement.
The whole damn thing! That doesn't count, huh? Then I guess I'd have to go with new speakers with a very close second going to the amp.
Aaron
...getting my edit on....
My next upgrade needs to be a dedicated HS room. I can't even listen to my system as is. -
2 answers. In my own system, which is 2-ch, I'd change my Marantz stereo rcvr to a Magnum Dynalab stereo rcvr. The MD is actually a Simaudio (sp?) amp/preamp combined w/a Magnum Dynalab tuner into a one-piece unit. Yes, I know I oughta aim for seperates, but I'm fixated on the MD stereo rcvr.
In a general sense, back when I had a tabletop mini-system, the effect of adding good speakers was unbelievable. Even a $100-$200 system from Target sounded vastly better with some entry-level bookshelfs from MTX, who is known for car, but also makes home stuff. If you have a system when none of the components are that good, I'd say go for spkrs first.Testing
Testing
Testing -
meestercleef, whatcha got for a Marantz there? If you ever think about parting with it, how bout you let me know?
For me it would be mono blocks.Political Correctness'.........defined
President of Club Polk -
Mono blocks....
Why? What brand/model? What are they to replace?
Cheers,
Curious RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
My total system is also getting a facelift.
Audio wise I'm a lock on B&K......tried and true..almost got takin out by Rotel but the preamp just smokes Rotels.Amps are alot closer.
Yes Troy I will be going seperates this time...away with the receivers forever.Once you cross there's no going back.
Ref50(out 4th Quarter) a ref 2220 2 channel and a ref7270 7 channel.
Speakers are the last on the what to buy list.Sub is locked need I say.But the lsi's are hanging tuff.time will tell.Dan
RuSsMaN
I'm looking for more clean power to replace my old Sony TA-N77ES amp/TA-E77ESD pre. They did very will with the 2B's, but I know the 2.3TL's would shine even more with a Class A, A/B amp. Under consideration are Bryston 7B-ST's, Belles 350 A's, Krell's older KSA line, Rotel RB-1090 dual mono (class
, maybe older Denon POA-6600's. I am open to suggestions/opinions. Anybody using any of the above?
F1nut, a future blockhead.Political Correctness'.........defined
I think my first step would be interconnects and/or speaker wire for both systems. Especially the under-utilized HS rig. But under-utilized = low priority.
Either this or get one of my amps repaired to add the stacked front main thing to my HT rig without having to move my Dynaco.
For video, the best thing I could do is get my old Panny repaired and put the Sony in the HS/bedroom rig. I don't watch many movies anymore, but if I did, I could really use a HDTV and a sub.
New HS rig: Dynaco amp & preamp driving Altec Lansing Segovias in different cabinets with a Sony Playstation for CD (very inconvenient) and a Sansui (hopefully) enroute.
Man oh man, where to start. Besides wires and connectors. If I can build some decent sounding single driver speaker with a high impedence, I'm looking at a cheap tube amp. My buddy might sell me his DBX preamp. He won't part with his 200w/ch Denon amp. This is probably good as I am currently drawn to tubes and high efficiency anyways. My hunger is on. It's just more on various speaker designs and building a system around them.
P.S. I know damn well that the biggest improvement would be to dig around the basement and finding those FM headphones that I got for Christmas a few years back. I listen to public radio alot and right now am listening to a jambox type thing that's around the corner. But for some reason this would be a waste of time in my otherwise audio experience seeking world. WE SUCK!Make it Funky!
Sounds like you have a really good list there. Which of those have you demoed and what was your take on them?Under consideration are Bryston 7B-ST's, Belles 350 A's, Krell's older KSA line, Rotel RB-1090 dual mono (class
Aaron -
Troy, you wouldn't be impressed. It's the SR4120, their current stereo rcvr, not one of the "classics". I think that you would do better with the current Rotel or Denon line. I got mine because I needed to do a trade-in, & the dealer was the only one in town who is very amenable to trade-ins. I'm not saying it's bad, but it's nothing special.Testing
Testing
Testing -
Gotcha, I though you had an older 22XX series or some such thing. Thanks though....
I'm not too proud, I'll take it when/if.......
Cheers,
Actually, I thought this thread was originally more about daydreaming than definite plans. I can't upgrade right now. The only thing about my rcvr that might make it even slightly attractive to a "high end" guy are the pre-outs, which would allow you to connect it to yer badass amp.Testing
Testing
Testing -
Thats why I'm eyeballin it brotha....when and if, when and if...... give a **** a shout.....
Cheers,
meestercleef,
No, it's a cool piece of gear, don't get me wrong it's just I don't have any REAL use for it but I'll snag an old 22 series just on principle.
TroyI plan for the future. - F1Nut -
BDT
for my small system. the two most recent improvments i made and they both made a difference. 1. mono blocks. Marantz MA500
i highly suggest going with mono blocks that are the same brand as your receiver. This way they will blend better, instead of mixing different brands. I would think they were designed to compliment each other if you stay within the same family.
2. interconnects between the mono blocks and the pre outs. I went with Catcables Silvercats. They added a little brightness but quite a bit more detail in the upper end. Bass did not change.. and only a slight openness in the mids. Very pleased with the Silvercats interconnect cables.
as for what i'd like to upgrade next.. well, i'm looking for a new rack to hold all the gear now. secondly.. i'd like to add a second, deeper sub.PolkFest 2012, who's going>?
'6 ch DVD audio is the future of recorded music!'
Wow, that is a **** sig line....
Cheers,
SiggyCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Aaron
None as yet, just been doing some homework. That is why I would like any feedback on those or other mono's.Political Correctness'.........defined
Man, Russ is making up for lost time.....
Cheers,
Siggy
If you've heard 6 channel DVD audio.. you'd probably agree. beats the heck out of 2 channel 16 bit audio hands down.
as for a **** sig line... if you only knew brother.
Beats 2ch? How about you take a poll around here, we will see which format is left standing....
Cheers,
Opps! wrong thread to be debating 2 ch vs 6 (much better) ch audio. my bad.
Danger boy quickly exits stage left. leaving skid marks on the floor
ciao!:pPolkFest 2012, who's going>?
bang for the buck, it would be a good subwoofer, of chorse. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
I'm with yeah on the 6 ch is the way of the future and is making a strong run right now.
Most people don't want 2 channel anymore.Go see what sells and what don't.
I personally like both,we all grew up in a mono to stereo world.Quad came and went now 6 ch music.Very good.
Whats all this **** you talk about Russ??Are you trying to come out of the closet or something????Spill the beans man we will still love ya.Dan
Talk about a gimmick, Mantis. I've never heard a live performance that came at me in 360 degrees. No way, not now, not ever!!!
Now, I would really like to hear about your vast and varied knowledge concerning mono blocks.
just a crazy F1nutPolitical Correctness'.........defined
