Z-680 plus R15 = YAH?
AzN_plyR
AzN_plyR Posts: 96
edited October 2005 in Speakers
Hey guys, I am on a set of logitech z-680's and I am wanting to replace the two front speakers with a pair of r15's from outpost that cost 50 bucks a pair..
Do you guys think this can happen wthout blowing up the amp or something? thanks.
Post edited by AzN_plyR on
  • Schris22
    Schris22 Posts: 983
    edited October 2005
    Aren't the z-680's hardwired? I just know most of my logitech products are hard wired. If not I'm sure you can do a splice. As far as the amp, I'm not immediately familiar with it, but the r15's aren't the hardest to drive and can probably be run by the z680's though your center would still be lacking
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • nadams
    nadams Posts: 5,877
    edited October 2005
    The Z-680 is not hardwired. They come with 5 bundles of speaker wire. Not exactly the biggest stuff, though.
    Not sure that what you're suggesting would sound good... at all. According to the specs on Newegg, you're getting 44.75 watts to each satellite speaker. But that doesn't say RMS or Peak. Who knows what the actual output is.... Not to mention the crossover points. Chances are the satellites are not getting a very full signal, so the R15's may sound worse because you're not going to get any low end out of them.
    Also, having different speakers for your front left and right is going to unbalance every other channel. They make those satellites all the same for a reason :)
    But hey, it's up to you. If they don't sound good, you can either sell them, or build yourself a nice office rig with 'em :)
    Ludicrous gibs!
  • AzN_plyR
    AzN_plyR Posts: 96
    edited October 2005
    well the logitech z-680's delivers 62 watts to each satellite and what is the difference between RMS and non RMS?
    but the pair is only 50 bucks and I probably can't go wrong with it for 50 bucks and can always reuse it if it doens't sound good :P
  • nadams
    nadams Posts: 5,877
    edited October 2005
    sorry, I took the satellite power minus the center channel power, then divided by 4. Didn't need to subtract the center power.... you are correct.
    RMS is supposed to be the power that the amp can deliver to the speakers for extended periods of time. More often than not, power ratings are grossly exaggerated. The peak power is the amount of power that it can theoretically deliver, at it's max output, for extremely short periods of time, right before the amp blows up :)
    But yes, the R15's are only $50 right now, so why not? They, by themselves, are worth $50, even if you can't use them on the z-680.
    Ludicrous gibs!
  • lanion
    lanion Posts: 843
    edited October 2005
    I have owned both a R50 and the z680, but never matched them up. I am not sure how well it will work. I remember the R50s upper range being very unpleasent but with a solid midrange, wheras the z680 speakers didn't have any major shortcomings except for center channel hiss. Then again, nothing about them blew me away. It's worth a shot, especially since the R50s are cute little speakers that worth $50 no matter how you use them, but no more than $50 I would say.
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
  • nadams
    nadams Posts: 5,877
    edited October 2005
    R15's we're talking about... R15s. The R50's are towers :)
    Ludicrous gibs!
  • Ferres
    Ferres Posts: 310
    edited October 2005
    I have done something similar with my altec lansing using Kef Q1's and worked well enough. But pc audio is not exactly audiophile grade.
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
