schtoopid computer question
sda2mike
sda2mike Posts: 3,131
edited April 2024 in Clubhouse Archives
the new look for the site is great! but too wide! how do i re-size it?
signed,
i'm so clueless :confused:
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited October 2005
    Scroll to the bottom and use the drop-down menu.
  • Mike682
    Mike682 Posts: 2,074
    edited October 2005
    go to drop down menu on bottom left of page and select widescreen. This actually makes the page more narrow on my work comp...
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • sda2mike
    edited October 2005
    Thank you sirs!!!! That did it!!! :D
  • nadams
    nadams Posts: 5,877
    edited October 2005
    Here's the reason behind it-
    If you're running a resolution below what the forum default skin is designed for, you'll have scroll bars at the bottom, because the forum default skin is a fixed size. It will not scale larger or smaller. The widescreen setting scales the skin to your resolution (this was originally created because we complained about having large amounts of white space on the sides at higher resolutions), so if you're larger or smaller than the forum default resolution, you need to set it to widescreen.
    I'm not sure why it doesn't just get set to scale all the time... i prefer to get good use out of my available screen real estate...
    Just out of curiosity, what resolutions are you guys running? I run 1280x1024 at work and home, which leaves huge amounts of white space on the sides of the page here if I don't set it to widescreen.
    I'm guessing you guys are running 800x600... or lower???
    Ludicrous gibs!
  • Mike682
    edited October 2005
    I'm running 1024x768 on all my comps (work & home).
    Mains: polk R30
    Center: polk CSi3
  • nadams
    nadams Posts: 5,877
    edited October 2005
    Wonder what they're scaling for, then...
    Ludicrous gibs!
  • sda2mike
    edited October 2005
    i run an 8 minute mile :confused:
  • Markymark
    Markymark Posts: 111
    edited October 2005
    if I choose widescreen, there is no white space around the foum template. I don't have the problem of having to scroll over, that is weird.
    <--- runs 1600x1200
    VR3 Posts: 29,631
    edited October 2005
    dittos
  • BIZILL
    BIZILL Posts: 5,432
    edited October 2005
    1280X1024 here. have a program at work in which it is imparative that i have numerous mini-screens open at one time.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
