schtoopid computer question
sda2mike
the new look for the site is great! but too wide! how do i re-size it?
signed,
i'm so clueless
signed,
i'm so clueless
Scroll to the bottom and use the drop-down menu.
go to drop down menu on bottom left of page and select widescreen. This actually makes the page more narrow on my work comp...Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Thank you sirs!!!! That did it!!!
Here's the reason behind it-
If you're running a resolution below what the forum default skin is designed for, you'll have scroll bars at the bottom, because the forum default skin is a fixed size. It will not scale larger or smaller. The widescreen setting scales the skin to your resolution (this was originally created because we complained about having large amounts of white space on the sides at higher resolutions), so if you're larger or smaller than the forum default resolution, you need to set it to widescreen.
I'm not sure why it doesn't just get set to scale all the time... i prefer to get good use out of my available screen real estate...
Just out of curiosity, what resolutions are you guys running? I run 1280x1024 at work and home, which leaves huge amounts of white space on the sides of the page here if I don't set it to widescreen.
I'm guessing you guys are running 800x600... or lower???Ludicrous gibs! -
I'm running 1024x768 on all my comps (work & home).Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
i run an 8 minute mile
if I choose widescreen, there is no white space around the foum template. I don't have the problem of having to scroll over, that is weird.
<--- runs 1600x1200 -
Mike682 wrote:I'm running 1024x768 on all my comps (work & home).
dittos- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
1280X1024 here. have a program at work in which it is imparative that i have numerous mini-screens open at one time.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments.
