WTB: AI-1 cable
fredv
fredv Posts: 923
edited October 2005 in Wanted (WTB) Classifieds
Yeah, I know, build it yourself ;) but I am simply no EE :o If you have a AI-1 SDA IC spare. I would like to buy it from you.
Thanks,
-fredv-
Post edited by fredv on
  • george daniel
    george daniel Posts: 12,096
    edited October 2005
    Fred, I don't think that it's that difficult to build, I'll let you know when I start/finish mine. I am pathetic when it comes to solder :)
  • fredv
    fredv Posts: 923
    edited October 2005
    Hi George,
    That makes 2 of us :D Pleaes let me know how it goes.
    Thanks,
    -fredv-
  • george daniel
    edited October 2005
    Will do, should start/finish saturday ;)
    SCompRacer Posts: 8,365
    edited October 2005
    This is what an original one looks like inside the box.
    George, can you still get the original plugs from polk or are you doing a custom connection?
  • Spawndn72
    Spawndn72 Posts: 453
    edited October 2005
    The cable they are talking about allows you to use monoblock amps with some of the SDA speakers. Not needed if you are using a common ground amp.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
    edited October 2005
    anonymouse wrote:
    That looks like a transformer inside that box. I thought this was a passive cable. What does that transformer do?
    Like Spawndn72 said. There are two seperate windings inside the transformer, and each one connects to a speaker. The juju happens through inductance in the windings so there is no hard wired connection between the speakers.
    F1nut Posts: 49,880
    edited October 2005
    It's called a isolation transformer.
  • madmax
    madmax Posts: 12,434
    edited October 2005
    It is a 1:1 transformer. At least close.
    madmax
    Vinyl, the final frontier...
  • fredv
    fredv Posts: 923
    edited October 2005
    Hi George,
    Just a ping to see you have done with the AI-1 cable?
    Thanks,
    -fredv-
  • bigyank
    bigyank Posts: 224
    edited October 2005
    I have an adcom gfa5800 and I'm looking into getting a pair of Polk SDA's and found through this establishment that I will need this cable or modify my amp to add a common ground.
    I would be very interested in seeing the steps required to build this cable.
    Thanks!
    Yank
    Polk Monitor 7
    Polk Atrium 55
    edited October 2005
    Thanks!
    Yank
    I can't link you direct to it. Go here and put your mouse pointer on "Publications" and click on "A1 Interconnect Instructions."
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2005
    If you mean the blade-blade connector, I got mine here; not sure if they carry the pin-blade, but worth looking...
    https://www.alliedelec.com/Search/ProductDetail.asp?SKU=750-3200&SEARCH=P%2D302%2DCCT&ID=&DESC=P%2D302%2DCCT
    SOPA
    edited October 2005
    Great! Thanks for the info. I'm set for now (have pin/blade NCG AI), but you never know when you may need something down the road a ways. Bookmarked...
  • bigyank
    bigyank Posts: 224
    edited October 2005
    Just to make sure I am clear on the terminology. The speakers I am considering have the cable supplied with the speakers when new. So when you say blade to blade you mean....?
    Polk Monitor 7
    Polk Atrium 55
  • Ricardo
    edited October 2005
    SDA speakers were made with two type of connetcors for the IC; some came with a blade-blade connector and some came with a pin-blade connector. If you are buying a pair that comes with the interconnect you should probably be ok...it will bring the one that fits that pair.
    SOPA
