AR 4X - Anyone heard these?
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited October 2005 in Speakers
Anyone heard these, how do they sound? I'm thinking of bidding on this auction - how much is too much $$$
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5813271114&sspagename=ADME:L:RTQ:US:1
  • shack
    shack Posts: 11,154
    edited October 2005
    I actually have a pair of those. I bought them new in 1969 or 70. Rated for 15 watts max. A really mellow sounding speaker (the classic "New England" sound). Sealed AS. With the grills off they look like crap...but that is the way they made them back then. An issue to be aware of. They are filled with fiberglass batting. Sometimes the fiberglass reacts with the adjustable pot (variable crossover) making the tweeters inoperable. It is nearly impossible to fine replacement pots. The pots can sometimes be cleaned to make them work and others have bypassed the pots alltogether. I have seen mint pairs of these go for $50 - $70. They are probably worth a look. They served me well for over 25 years. (My pots need repairing).
  • shack
    shack Posts: 11,154
    edited October 2005
    Here are some pics. There have been some dicussions over at Audio Karma as to how to rehab these if you are interested.
  • AsSiMiLaTeD
    edited October 2005
    Yeah, they are purdy, that's for sure - at least in the pics...are they wood veneer?
    I may snag them up...
  • shack
    shack Posts: 11,154
    edited October 2005
    Some of the early ones were solid wood but later on they were Walnut veneer. Heavy and solid cabs. Make Polks stuff (which is very good) seem lightwieght.
