PSW12 in-wall installation
Rittel
I am building a home theatre room from scratch. I will be using RC55i for 6 speakers and PSW12 for the bass. I can install it in the wall or leave it out. Any recommendations? The room is 18'x20'
Thanks,
Thanks,
Post edited by Rittel on
Welcome to CP!
It was designed to be a stand alone. You have more placement options with it movable. Bass response can change drastically with just a little moving and tweaking of the sub. I wouldn't want to lose this advantage.
Builtins look cool, but are a usually a compromise to the best possible sound.
Just my .02,
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Also, Polk is getting ready to come out with in-wall subs.
http://www.polkaudio.com/homeaudio/products/hidden/inwallsubs/
