PSW12 in-wall installation
Rittel
Rittel Posts: 1
I am building a home theatre room from scratch. I will be using RC55i for 6 speakers and PSW12 for the bass. I can install it in the wall or leave it out. Any recommendations? The room is 18'x20'
Thanks,
Post edited by Rittel on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2005
    Welcome to CP!
    It was designed to be a stand alone. You have more placement options with it movable. Bass response can change drastically with just a little moving and tweaking of the sub. I wouldn't want to lose this advantage.
    Builtins look cool, but are a usually a compromise to the best possible sound.
    Just my .02,
    DG
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2005
