stands
eaadams
eaadams Posts: 213
edited July 2002 in Speakers
Should my mains (35i's) be level or can they be higher with my center (CS40)
Post edited by eaadams on
  • mantis
    mantis Posts: 17,322
    edited July 2002
    You can use the 2 foot rule.....above or below.
    Dan
  • Aaron
    Aaron Posts: 1,853
    edited July 2002
    Is that in the Mantis Hi-Fi Handbook, too? :p
    Aaron
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2002
    2ft sounds good to me. I'd add that you would also want this +/- 2ft arc to have the tweeters as close to ear level as possible (seated at your sweet spot).
    Cheers,
    Russ
  • mantis
    edited July 2002
    You know I will just have to write the damn book.Then you guys can just use it as a be all end all of no arguing any of my points which they are all facts and not opnions....
    Agreed with Russmans post(doesn't happen often),He's right on target.:p :lol::D
    Dan
  • gidrah
    gidrah Posts: 3,049
    edited July 2002
    Yeah, within 2 feet should be okay. Beyond that you will need to adjust the delay. I'll assume you will point them toward your seating spot.
    Make it Funky! :)
