stands
Should my mains (35i's) be level or can they be higher with my center (CS40)
Post edited by eaadams on
You can use the 2 foot rule.....above or below.Dan
Is that in the Mantis Hi-Fi Handbook, too?You can use the 2 foot rule.....above or below.
Aaron -
2ft sounds good to me. I'd add that you would also want this +/- 2ft arc to have the tweeters as close to ear level as possible (seated at your sweet spot).
Cheers,
You know I will just have to write the damn book.Then you guys can just use it as a be all end all of no arguing any of my points which they are all facts and not opnions....
Agreed with Russmans post(doesn't happen often),He's right on target.:p
Dan
Yeah, within 2 feet should be okay. Beyond that you will need to adjust the delay. I'll assume you will point them toward your seating spot.Make it Funky!
