outlaw lfm2 or svs pb10-isd
dagame27
Hey guys I am going back to school to get my masters, so this will be for a small room. It's main purpose will be for music, but will be used for movies as well. I am going to be running a 3.1 channel system down there leaving my surrounds behind. Ill be using a HK 235 w/ rti70's up front and a csi40 in the center. I also will add a 3 channel amp or 3 monoblocks. What do you think would be the best subwoofer for my situation? Any other brand reccomendations as well? I would like to stay under $500. Thanks
Chris
Chris
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
Hsu STF 1 or 2 for music and movies in a small room are similar options to the Outlaw. You can't go wrong with any of them.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
another vote for STF2, I loved mine for music when I was using them with a pair of B&W bookshelves. easy to blend with your mainsLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Any of the subs mentioned above will get you in "trouble" if you are in a dorm or apartment building. They should all do great for music and home theater with the HSU/Outlaw design getting the nod for music.See profile for rigs. Nothing else here.
The Outlaw LFM-2 is similar to the Hsu Research STF-1, but with a somewhat larger enclosure and a slightly deeper port tuning frequency."What we do in life echoes in eternity"
SVS -
thanks for the help guys. It looks like I'll look for a deal used, if not I'll get the outlaw.ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
