outlaw lfm2 or svs pb10-isd
dagame27
dagame27 Posts: 600
Hey guys I am going back to school to get my masters, so this will be for a small room. It's main purpose will be for music, but will be used for movies as well. I am going to be running a 3.1 channel system down there leaving my surrounds behind. Ill be using a HK 235 w/ rti70's up front and a csi40 in the center. I also will add a 3 channel amp or 3 monoblocks. What do you think would be the best subwoofer for my situation? Any other brand reccomendations as well? I would like to stay under $500. Thanks
Chris
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited September 2005
    Hsu STF 1 or 2 for music and movies in a small room are similar options to the Outlaw. You can't go wrong with any of them.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • ohskigod
    ohskigod Posts: 6,505
    another vote for STF2, I loved mine for music when I was using them with a pair of B&W bookshelves. easy to blend with your mains
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
    billbillw Posts: 8,105
    Any of the subs mentioned above will get you in "trouble" if you are in a dorm or apartment building. They should all do great for music and home theater with the HSU/Outlaw design getting the nod for music.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    The Outlaw LFM-2 is similar to the Hsu Research STF-1, but with a somewhat larger enclosure and a slightly deeper port tuning frequency.
    SVS
  • dagame27
    dagame27 Posts: 600
    thanks for the help guys. It looks like I'll look for a deal used, if not I'll get the outlaw.
