lsi9 speaker stands
snakebitten
Would atlantis pro speaker stands be a good match with lsi9? I tried to find what the weight limit was on these but could not find anything out. I found a good price but wanted to make sure they would work with the 9's.
Any input would be appreciated.
Post edited by snakebitten on
Those should work just fine. I have my 9's on a much lighter weight stand than that (Sanus EF28) and they are doing fine.
Can I ask where you found the good price? Cheapest I found them is $99 at Audio Advisor. Have you found better?HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Thanks for the reply. Those are the ones I am looking at (audio advisor). I've been looking around alot and those looked good at a decent price.
cmy330go- do you use stands for your lsi7's?
snakebitten wrote:cmy330go- do you use stands for your lsi7's?
No. I have some odd speaker mounts that I slightly modified, and wall mounted them on their sides.
HT
2 CH
nice
I have a set of Target HR70's, which I love. They are stout steel with welded bases and platforms, and I filled them with sand. They are like two pillars of stone now, and the plat6form is nice and big to give good llateral support for the LSi9's. Here are some pics from an earlier thread on the subject:
http://www.polkaudio.com/forums/attachment.php?attachmentid=6596
http://www.polkaudio.com/forums/attachment.php?attachmentid=6599Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
