Anyone here have an SVS pb10isd? Looking for feedback.
aaharvel
aaharvel Posts: 4,489
edited April 2024 in Clubhouse Archives
I'm not upgrading anytime soon- as my Velodyne does very well in my 1,100 sqft condo, especially with music. but am considering something more powerful if I decide to move back to Asheville (Greensboro, NC blows chunks guys. That's free advice.) $400 seems reasonable. I would never invest more in a subwoofer.
Any feedback would be nice thanks. :cool:
H/K Signature 2.1+235
Jungson MagicBoat II
Revel Performa M-20
Velodyne cht-10 sub
Rega P1 Turntable
"People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • clifselina
    clifselina Posts: 41
    edited September 2005
    I just finished potting together a kit for a VMPS sub. It was $409 delivered and went together very easily. First impressions (before break in) is that it is a very powerful, musical sub. I had to go to Home Depot and get a bunch of little rubber feet to put behind the pictures on the wall, as they are rattling and walking themselves crooked. Pretty good bang for the buck.
    So what if those speakers are as big as a Subaru and cost twice as much? You'll never have to trade these babies in and when you die, they can bury you in them.
    And, if you can't afford them, F***ing FINANCE them!
  • aaharvel
    great. SVSpb10ISD anyone?
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • Mike682
    Mike682 Posts: 2,074
    andrew,
    I found this review on the web:
    Click here for the direct link review (zip pdf file)
    http://www.soundenvironments.org/filemgmt/visit.php?lid=5
    Other reviews, etc.. the link above is actually the last one on this page.
    http://www.soundenvironments.org/filemgmt/index.php
    Hope this helps
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • PolknPepsi
    PolknPepsi Posts: 781
    I have it's bigger brother the 2039+ and it is more than I'll ever use. I thought about selling mine off and going with the PB10ISD to save space. Never having heard it I would still recommend it knowing what SVS is all about.
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • aaharvel
    no internal bracing?
    nevermind then. I'll keep my $200 'wondersub'. Thanks for the feedback though!
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • audiobliss
    audiobliss Posts: 12,518
    Yeah, but...you'll be farther from Foreign Cars Italia!!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • aaharvel
    that's a risk i'm willing to take.
    btw- the 2006 Z06 is awesome. And I hate American cars.
    http://www.edmunds.com/apps/vdpcontainers/do/vdp/articleId=107094/pageNumber=1
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • tryrrthg
    tryrrthg Posts: 1,896
    here is a review written by Club Polk's own Dr. Spec, although he's been a stranger lately.
    Dr. Spec's review
  • Ricardo
    Ricardo Posts: 10,634
    I've got one; couldn't be happier....you could say my room is 20 x 20 because it's open on one side, and this thing ROCKS....on bassy action scenes the walls shake....I recommend it!!!!
    SOPA
    VR3 Posts: 29,762
    Take it a step up...
    PB10ISD has next to no features... No bracing in a long, 3/4" MDF enclosure.
    Its main goals are entry level HT, hit the possible lowest note while smashing everything in the house.
    The PB12 ISD and PCI series would be the way to go for music. IMO I purchased my PCi 25-31 for 580 shipped to my door... ;)
  • tenor12
    tenor12 Posts: 9
    I also put together a VMPS sub ("Larger sub") and I like it very much. It should be noted, though, that the VMPS subs are passive, which means you might have to spring for a separate amp, depending on your current amplification setup. On the plus side, the VMPS subs are very efficient - mine shakes the walls even when run by a 30WPC power amp.
  • clifselina
    I mounted a 250W sub amp I got from Parts Express in the back of the enclosure. That was to free up power from my amp to my main speakers, which are some Infinity Kappa 6 speakers. (My Polk’s are in another room)
    The Kappa speakers are inefficient, but since I have the crossover set at 100 Hz, more current from the amp is not wasted trying to drive inefficient woofers and I have more headroom now.
    I first heard the VMPS subs at a friend's house and was blown away by the power and efficiency (he had them run passively).
    I have to say it sure was very gratifying to have my wife run out of the bedroom and open the front door to check for clouds after she heard and felt the thunder from a movie.
    :D
  • dkg999
    dkg999 Posts: 5,647
    I have both the PB10 and the 20-39 PC+ subs from SVS. I run the 20-39 as the main sub, and the PB10 as the second rear sub. My room is about 18'x20', and is the living room of an apt. Running both subs real low, I get incredibly detailed bass, that fills the room, without shaking all the neighbors. The PB10 is pretty impressive at its price point. Very clean, detailed bass. Not a lot of features, not a lot to play with, however it lives up to the SQ the SVS is known for. If you don't mind DIY, I would definetely recommend the Parts Express or other kits in the same price range. I have heard some of them, and they are very good. For delivered to your door, plug it in and scare the cat type convenience, hard to beat the PB10. I don't run very high SPL, so I can't comment on the lack of internal bracing. I would ask, is it really something "I" can hear, or has the reviewer made me believe it is an issue "I" might possibly hear, or convince myself I can hear? That's why I don't read too many paid advertisements, I mean reviews :rolleyes:
    DKG999
