Component Cables
swerve
Hey my fellow Polk friends!
My auntie just bought a new TV. I need to show her some decent component cables. I mean they don't have to be anything absolutely super. I was looking @ knukonceptz (where I got my car wiring.) But I'd like your recomendations as well!
thanks,
adam
thanks,
adam
cats.vans.bag...
Post edited by swerve on
Adam, here's a more reasonably-priced set that'll do the job.
Thanks... can anyone kind of give me an explanation on what these will do? I'm very ignorant about all things Home Entertainment.cats.vans.bag...
Adam, "component" cables are a set of three cables which connect a source component such as a DVD player which has three component outputs to a TV which has three component inputs. If auntie has equipment which can use the component connections it generally results in a somewhat better picture than a single cable "composite" or "S-Video" connection.
John K. wrote:Adam, here's a more reasonably-priced set that'll do the job.
did i read that right? $7.00? :eek: -
Right on. so those will be okay then?! If so I'll order them tomorrow.cats.vans.bag...
Wait.....
Those are the same quality that the cable company uses. They are horrible. Not so much in performance but built quality. The connectors easily come off and get loose.
You get what you pay for.
If you live near a Tweeter, Check out Pro Solutions for your budget line cables. these cables are better built and don't cost an arm and a leg.Dan
I went with cables from http://www.ramelectronics.net --> found them on this website. They should be coming in 2-3 days, the prices looked good for all the equipment they offer.Receiver: Denon-3802
Pre-Amp: (2) Outlaw 200-m
Fronts: Lsi9's
Center: CS1
Rear: R15
Sub: 12" Velodyne
TV: Sony 42" LCD - KDF-E42A10 -
Signalcable is a good place to get some wires. they provide Pro quality cables at a good solid price.
www.signalcable.com
DanDan
I like http://www.partsexpress.com
Specifically their component cables here.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=181-672
The price seems a bit high, I only paid $30 for 12 foot cables.
Pioneer 1018
Polk RTIA5's
CSIA6
RC80I's
SVS PB12-nsd -
Nice find, 75ohm rated, lots of shielding for only 7 bones. They look exactly like the basic Monster component cable. I doubt swerve will rip the ends off.
knukonceptz home audio cables are ROCK SOLID, I'm sure their component cable would be too.
