Car Subwoofer in HT use?
dipiazza
Hey all, i was able to aquire 2 Infinity 1230W 12'' Car Subwoofers for extremely cheap. At the moment i have no use for them in an auto, i was wondering if it would be possible or even worthwhile to build an enclosure and use them as HT subs? Has anyone had any experience with this sort of thing? Does a Car sub driver have basically the same effect as a HT sub? i would purchase an amp for in home use and build an enclosure...
Let me know if this is worth it since i just have these subs sitting around, and could use an extra home sub. thanks guys!
-Jake
-Jake
Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
Post edited by dipiazza on
They will work, just match the amp you choose with the ohm configuration of the subs. Do a little digging on box building.
Make sure you model them in something like winisd before you spend much time building. From what I read most car subs rely a lot on cabin gain and don't dig very deep in home applications. Sorry I don't know about the specific ones you purchased but am sure if you post the t/s parameters someone would help with a box size and an idea as to how low they would go.
Scott -
Heres Some info on the subs, if you all could reccomend an amp, or box plans that would be awesome, thanks guys...
Diameter: 12" (300mm)
Sensitivity @ 2.83V/1m: 90dB
Power Handling: 300W RMS, 1200W Peak
Frequency Response: 23Hz 400Hz
Impedance per Voice Coil: 4 ohms
Voice Coil Diameter: 2" (51mm)
Mounting Depth: 6-1/4" (159mm)
Overall Diameter: 12-3/8" (315mm)
Cut-Out Diameter: 11-1/4" (286mm)
Basket Displacement: 0.11 ft3
-JakeTerps Swimming!
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
