Driver Connections
thehaens@cox.net
thehaens@cox.net Posts: 1,012
What type of connectors are "pinched" on to the driver/woofer terminals? I am googling wire connectors and coming up with much to broad of a search. I am looking at re-wiring my SRS 1.2's and need to get a lot of connectors for all them drivers...
Scott
Post edited by thehaens@cox.net on
  • Mjr7531
    Mjr7531 Posts: 856
    edited August 2005
    Check Parts Express, though, they might not be uber quality you may be looking for, it's worth a shot.
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-810
  • Polk65
    Polk65 Posts: 1,405
    edited August 2005
    Female disconnect / f-disconnect
    Madisound.com has non-gold connectors for $0.25 each. Search their site for "quick connect".
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2005
    You can get those at Wal-Mart, gas stations, Radio Shack, any automotive store, etc.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2005
    They are generic spade terminals....go to the auto store, as suggested by PT.
    The RS's around here stopped carrying the good stuff....all catalog now. F that, I'll order something else if it's that easy.
  • thehaens@cox.net
    edited August 2005
    True, I should of put in my request that I wanted some "better" than stock. The speakers deserve some high quality copper running through them. I don't want to "upgrade" all the wiring and use some shotty connector. I realize the difference would most likely not be audible, but it would make me feel better at the end of the day..
  • dorokusai
    edited August 2005
    Streetwires and most Car Audio/12V manufacturers make gold terminals...they are typically cheaper than the "home audio" versions.
  • thehaens@cox.net
    edited August 2005
    Thanks all............I'll do the search....maybe I'll just solder the wire to the speaker...PE does have "gold plated" ones though, that may just be the ticket..
    POLK65 - You have PM, I have something for you..
    Scott
