Driver Connections
thehaens@cox.net
What type of connectors are "pinched" on to the driver/woofer terminals? I am googling wire connectors and coming up with much to broad of a search. I am looking at re-wiring my SRS 1.2's and need to get a lot of connectors for all them drivers...
Scott
Scott
Post edited by thehaens@cox.net on
Check Parts Express, though, they might not be uber quality you may be looking for, it's worth a shot.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-810 -
Female disconnect / f-disconnect
Madisound.com has non-gold connectors for $0.25 each. Search their site for "quick connect". -
You can get those at Wal-Mart, gas stations, Radio Shack, any automotive store, etc.
They are generic spade terminals....go to the auto store, as suggested by PT.
The RS's around here stopped carrying the good stuff....all catalog now. F that, I'll order something else if it's that easy.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
PolkThug wrote:You can get those at Wal-Mart, gas stations, Radio Shack, any automotive store, etc.
True, I should of put in my request that I wanted some "better" than stock. The speakers deserve some high quality copper running through them. I don't want to "upgrade" all the wiring and use some shotty connector. I realize the difference would most likely not be audible, but it would make me feel better at the end of the day.. -
Streetwires and most Car Audio/12V manufacturers make gold terminals...they are typically cheaper than the "home audio" versions.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks all............I'll do the search....maybe I'll just solder the wire to the speaker...PE does have "gold plated" ones though, that may just be the ticket..
POLK65 - You have PM, I have something for you..
Scott
