Bi-Wire or Wired Jumper for fronts
landry_p2000
landry_p2000 Posts: 1,313
edited September 2005 in Basic Hookup/Wiring Questions
Will a set of bi-wire speaker cables do the same job as a wire jumper, and what materials would I need to make my own jumpers for front speakers? Maybe a 3" piece of 12g speaker cable with spade terminators on the ends, and removing the metal flat jumpers from the speakers?
Is there a noticeable difference in the bi-wired or jumper set-up? Are they both better than the factory metal jumpers? I know I am asking alot of questions, I just want to be sure I get it right.
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
Post edited by landry_p2000 on
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2005
    Noticeable is subjective. I used 12awg and spades for mine.
  • ward91
    ward91 Posts: 338
    edited August 2005
    ive bi wired my speakers (i think i have aneyway) i reamoved the jumpers and ran 2 sets of 78 strand cable (£15 from maplin) to the terminal on my amp ,ive just twisted the ends together and put them in the same output. i dont even no what effect this has. ive never thought of just doing my own jumpers. (dont just take my oppinion wait for more expereance) i dont even know wether i should get better cable because a universety did a test and 13a mains cable barely has a heareble change to more expensive cables.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • Willow
    Willow Posts: 11,283
    edited August 2005
    leftover cable and bare ends on mine
  • landry_p2000
    edited August 2005
    Thanks for the input. Do you have a pic of the finished product?
  • landry_p2000
    edited August 2005
    Bare wire throough the post terminal holes under the red and black post covers? I may go with the spades for this. Radio Shack should have the ones I need. Why do so many guys bi-wire?
    Thanks Willow.
    Check your pm.
  • michael_w
    michael_w Posts: 2,813
    edited August 2005
    I just use a 6" length of spare 12 awg bare wire with bananas running to the top posts. I don't ever remove them so not much need for spades at the moment. I'm not sure I noticed a difference but it was cheap and looks kinda cool.
  • PolkThug
    edited August 2005
    http://www.polkaudio.com/forums/attachment.php?attachmentid=4018
  • McLoki
    McLoki Posts: 5,231
    edited August 2005
    You might look at this thread that I started when I was trying to make this decision.
    Michael
  • landry_p2000
    edited August 2005
    Thanks for the pics fellas. I am on the right path now. I will post pics once I finish my "custom" jumpers. This is my plan, sort of a cross between McLoki and PTs jumpers. Top posts will have 12g wire about 2"-3" long connected with spades, and the bottom posts will be connected with banana plugs. Then I will plug the banana plugs from the speaker cables in the top posts.
  • landry_p2000
    edited August 2005
    Well guys, after I left work today I went to Radio Shack, and this is what I came up with. A couple of sets of banana plugs, 3" 12g AR cable for both towers, and a package of spades.
  • landry_p2000
    edited August 2005
    I also found out that speaker cable jumpers are a far better conductor of sound than those flat metal jumpers. My overall sound improved, including deeper bass, more clear and pronounced highs and mids. I was able to get room rattling bass from my towers without the use of my PSW505. To anyone out there running those flat jumpers, you should give it a shot, and I think you will be glad you did it.
  • beardog03
    beardog03 Posts: 5,550
    edited August 2005
    That`s what I did...except I have it the other way around...mine plugs into the bottom posts...don`t think it matters though
    seems to sound better than the metal jumpers do
    my Parasound amp is set up for bi-wire application, so on the 2 ch rig I use 2 seperate wires...
    how does it sound ?
    did you notice a difference ?
    either way , it looks cool
    thats some fat cable ya got there son..!!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • landry_p2000
    edited August 2005
    how does it sound ?
    Thanks alot Bear. I noticed a definite improvement in sound. I would recommend this "upgrade" to everyone. That is some Acoustic Research 12g cable from Best Buy. The 30 foot spool was $29.99. :D
  • Willow
    edited August 2005
    Nice job, man you don't waste time. !! :D
    As for bi-wiring I don't know why people do this. I have tried it and for the extra cable price it was not worth the improvement.
  • DC106
    DC106 Posts: 10
    Maybe I'm missing something, but if you're biwiring, it looks to me like you only need about 2 ft. of extra cable, right?
  • PolkThug
    Bi-wiring is two sets of full length cable back to the receiver/amp.
