Setting up Onkyo tx-sr601
zeroimpact
Hi there,
I was wondering if anyone can point me in a direction (or help) in getting the
best set up for the following config setup (or at least a good starting point)
for :
- Receiver Onkyo tx-sr601
- Sub PSW10
- F L/R Monitor 60
- Center CS2
- Surround Monitor 40
- Onkyo Sp401 DVD player
Do I set the front speakers to Large, and the Center and surrounds to small ?
and what would a good cross over rate be for the sub ?
or where can I get some good documentation in understanding all the technical jargon to try and set up a good config
what would be good DVD's or music CD's be to use in testing the setup ?
thanks :cool:
for :
- Sub PSW10
- F L/R Monitor 60
- Center CS2
thanks :cool:
Post edited by zeroimpact on
For a starting point use, all speakers to small and a crossover of 80hz, and calibrate your speaker levels. Then try higher and lower crossovers, your front speakers large and small, and compare.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
Your Onk's manual goes over the recommended settings for speakers based upon their ability to handle bass Hz. In taking a quick look at your speakers I would set my fronts to large the others to small and start with the 80 hz crossover.
You will need to determine what sounds best to you.
As stated it is most important to calibrate your speakers using the Onk's mic or a Sound Pressure Level meter.
Have fun.
RT1 -
reeltrouble1 wrote:Your Onk's manual goes over the recommended settings for speakers based upon their ability to handle bass Hz. In taking a quick look at your speakers I would set my fronts to large the others to small and start with the 80 hz crossover.
Have fun.
RT1
That is good advice. My 601 is at; front L/R and center set to "large." The rears and back surround set to "small." I have the CSi3, but over time I have realized that it does better on "large." The crossover is set at 80Hz as well. Hope this helps and welcome to the forum.Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
Like others have said, it is very important to calibrate the output using an SPL meter.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
thanks for the info
At least it helps ... sometimes the manuals are overloaded with info
and it helps just speaking to other ppl that can give there 2c
cheers -
good luckReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
