Setting up Onkyo tx-sr601
zeroimpact
zeroimpact Posts: 2
Hi there,
I was wondering if anyone can point me in a direction (or help) in getting the
best set up for the following config setup (or at least a good starting point)
for :
- Receiver Onkyo tx-sr601
- Sub PSW10
- F L/R Monitor 60
- Center CS2
- Surround Monitor 40
- Onkyo Sp401 DVD player
Do I set the front speakers to Large, and the Center and surrounds to small ?
and what would a good cross over rate be for the sub ?
or where can I get some good documentation in understanding all the technical jargon to try and set up a good config
what would be good DVD's or music CD's be to use in testing the setup ?
thanks :cool:
Post edited by zeroimpact on
  • TheReaper
    TheReaper Posts: 636
    edited August 2005
    For a starting point use, all speakers to small and a crossover of 80hz, and calibrate your speaker levels. Then try higher and lower crossovers, your front speakers large and small, and compare.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2005
    Your Onk's manual goes over the recommended settings for speakers based upon their ability to handle bass Hz. In taking a quick look at your speakers I would set my fronts to large the others to small and start with the 80 hz crossover.
    You will need to determine what sounds best to you.
    As stated it is most important to calibrate your speakers using the Onk's mic or a Sound Pressure Level meter.
    Have fun.
    RT1
  • landry_p2000
    landry_p2000 Posts: 1,313
    edited August 2005
    Have fun.
    RT1
    That is good advice. My 601 is at; front L/R and center set to "large." The rears and back surround set to "small." I have the CSi3, but over time I have realized that it does better on "large." The crossover is set at 80Hz as well. Hope this helps and welcome to the forum.
    Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
    Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
  • Mike682
    Mike682 Posts: 2,074
    edited August 2005
    Like others have said, it is very important to calibrate the output using an SPL meter.
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • zeroimpact
    zeroimpact Posts: 2
    edited August 2005
    thanks for the info ;)
    At least it helps ... sometimes the manuals are overloaded with info
    and it helps just speaking to other ppl that can give there 2c
    cheers
  • Mike682
    edited August 2005
    good luck
    Mains: polk R30
    Center: polk CSi3
