LSi + Denon
jvilagi
jvilagi Posts: 2
Dear Friends,
I need to change the amp for my new LSi
speakers. What do you think about the Denon AVR-3805?
Thanks a lot!
Post edited by jvilagi on
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2005
    Welcome to the club! Here are some threads for you to read. If you want more just do a search on Denon & LSI. You will be reading for days, but in the end you will be able to make an informed decision.
    FYI The Denon is a reciever not a separate amplifier. However you can hook up a separate amp to the Denon to give you the power you will need to drive your LSI's to their full potential.
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=28492&highlight=lsi+and+denon
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=28292&highlight=lsi+and+denon
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=26723&highlight=lsi+and+denon
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=25864&highlight=lsi+and+denon
  • ezc
    ezc Posts: 426
    edited May 2005
    The 3805 can drive the LSi's at lower levels but is not reccomended. The receiver is rated at 6ohm & above. The LSi are 4ohm rated. If driving the speakers at louder levels you amy clip the receiver or it may run real warm. the better would be either a receiver like Rotel, B&K, sunfire & a few other that can drive 4 ohm well. Other than that a seperate amp would be the other way to go!
  • rscamer
    rscamer Posts: 70
    edited May 2005
    I run my 3805 with my 4 ohm rt12c" and it has not been any problem I usually never listen at low volumes either.
  • ezc
    ezc Posts: 426
    edited May 2005
    The 3805 is rated down to 6 ohm. We are a dealer for Denon & if Im not mistaken there is a lable or sticker on the back near the binding post for speakers that state speaker impedance 6 ohm min - 14 or 16 ohm. If you are driving LSi's you should use a receiver or amp rated for the speakers. I also know that first hand, Upon upgrading to LSi's, I ended up purchaseing a Rotel receiver that had enough power to drive the speakers. AI didnt want to blow a driver while playing the system loud due to not enough power. Remember speakers usually blow beacuse your amp dosnt have enough power to drive them correctly. With my old receiver the LSiS also just didnt sound good with more power they woke up!
  • rscamer
    rscamer Posts: 70
    edited May 2005
    Well I guess i should start looking for a good 2 channel amp to run my fronts. Anyone have one for a good price willing to ship to canada??
  • ezc
    ezc Posts: 426
    edited May 2005
    A good two channel amp will be a good upgrade! We have recently added a 2ch amp to our system, run the front mains off the amp & the center & surrounds off the Rotel receiver. I have tried SS amps & they sounded very good but once I tried a tube amp my search was over for now. We are using a BAT VK-60 to drive the 15's. I have finally found the sound I wanted & at this time I'm satisfied. Heres a link to pics of our systems http://www.ezconnection.org./ezcsystem.htm
  • jvilagi
    jvilagi Posts: 2
    edited May 2005
    Thanks a lot for everybody!!!
    I think I will need more time and more "testing sessions" for check the correct one. The second option after de Denon is the Rotel. Will see... and will check...
    Thanks again!!!
    Jordi
  • RoosterD
    RoosterD Posts: 36
    edited July 2005
    I just bought the 3805 and the LSi series and have had no heat or any other issues so far (5 days lol). I did find in the owner's manual for the Denon that it is rated (under dynamic power) 210W at 4 ohms x 2 channel and 240w x 2 (2 ohms). Just thought I'd mention it.
    Denon 3805S
    Denon 3910S
    Polk LSi 15's
    Polk LSi F/X's
    Polk LSi C
    Boston Pro 10" DIY Sub
    Samsung 5678W DLP 1080P
    PS3
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited July 2005
    Slow roasting is for coffee,
    but if you prefer your receivers that way, be my guest.;)
    SCompRacer Posts: 9,128
    edited July 2005
    I drive an in-wall/ceiling surround system with a 3805. You can get by with LSi7's OK, but once you start getting into LSi9's, you need some torque to drive them. I have a 200 watt amp on my R & L front LC265i's (think LSi9's) and it definitely makes a difference. Audition some music with deep bass and you'll know why. I've used a tune off Toni Braxton's Secrets CD, Your Makin Me high, to show folks the difference between mud and tight drums.
  • beardog03
    beardog03 Posts: 5,550
    edited July 2005
    waaaaaaaaaaaa!!
    instant classic...!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
