LSi + Denon
jvilagi
Dear Friends,
I need to change the amp for my new LSi
speakers. What do you think about the Denon AVR-3805?
Thanks a lot!
Thanks a lot!
Post edited by jvilagi on
Welcome to the club! Here are some threads for you to read. If you want more just do a search on Denon & LSI. You will be reading for days, but in the end you will be able to make an informed decision.
FYI The Denon is a reciever not a separate amplifier. However you can hook up a separate amp to the Denon to give you the power you will need to drive your LSI's to their full potential.
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=28492&highlight=lsi+and+denon
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=28292&highlight=lsi+and+denon
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=26723&highlight=lsi+and+denon
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=25864&highlight=lsi+and+denonMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
The 3805 can drive the LSi's at lower levels but is not reccomended. The receiver is rated at 6ohm & above. The LSi are 4ohm rated. If driving the speakers at louder levels you amy clip the receiver or it may run real warm. the better would be either a receiver like Rotel, B&K, sunfire & a few other that can drive 4 ohm well. Other than that a seperate amp would be the other way to go!
I run my 3805 with my 4 ohm rt12c" and it has not been any problem I usually never listen at low volumes either.
The 3805 is rated down to 6 ohm. We are a dealer for Denon & if Im not mistaken there is a lable or sticker on the back near the binding post for speakers that state speaker impedance 6 ohm min - 14 or 16 ohm. If you are driving LSi's you should use a receiver or amp rated for the speakers. I also know that first hand, Upon upgrading to LSi's, I ended up purchaseing a Rotel receiver that had enough power to drive the speakers. AI didnt want to blow a driver while playing the system loud due to not enough power. Remember speakers usually blow beacuse your amp dosnt have enough power to drive them correctly. With my old receiver the LSiS also just didnt sound good with more power they woke up!
Well I guess i should start looking for a good 2 channel amp to run my fronts. Anyone have one for a good price willing to ship to canada??
A good two channel amp will be a good upgrade! We have recently added a 2ch amp to our system, run the front mains off the amp & the center & surrounds off the Rotel receiver. I have tried SS amps & they sounded very good but once I tried a tube amp my search was over for now. We are using a BAT VK-60 to drive the 15's. I have finally found the sound I wanted & at this time I'm satisfied. Heres a link to pics of our systems http://www.ezconnection.org./ezcsystem.htm
Thanks a lot for everybody!!!
I think I will need more time and more "testing sessions" for check the correct one. The second option after de Denon is the Rotel. Will see... and will check...
Thanks again!!!
Jordi -
I just bought the 3805 and the LSi series and have had no heat or any other issues so far (5 days lol). I did find in the owner's manual for the Denon that it is rated (under dynamic power) 210W at 4 ohms x 2 channel and 240w x 2 (2 ohms). Just thought I'd mention it.Denon 3805S
Denon 3910S
Polk LSi 15's
Polk LSi F/X's
Polk LSi C
Boston Pro 10" DIY Sub
Samsung 5678W DLP 1080P
PS3 -
Slow roasting is for coffee,
but if you prefer your receivers that way, be my guest.;)HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I drive an in-wall/ceiling surround system with a 3805. You can get by with LSi7's OK, but once you start getting into LSi9's, you need some torque to drive them. I have a 200 watt amp on my R & L front LC265i's (think LSi9's) and it definitely makes a difference. Audition some music with deep bass and you'll know why. I've used a tune off Toni Braxton's Secrets CD, Your Makin Me high, to show folks the difference between mud and tight drums.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Dennis Gardner wrote:Slow roasting is for coffee,
waaaaaaaaaaaa!!
instant classic...!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
