Palm OS vs. Pocket PC
Early B.
Early B. Posts: 7,900
edited April 2024 in Clubhouse Archives
Looking for a low cost PDA. I was wondering which one is better -- Windows-based or Palm-based operating system? I'm specifically looking for the one that's more user friendly for basic functions such as word processing, phone book and calendar.
Thanks.
"God grooves with tubes."
  • janmike
    janmike Posts: 6,146
    edited July 2005
    What do you consider Low Cost? (I have a old Handspring sitting around that uses palm software)
    Other things you may want to consider are:
    Do you want to link your PDA back to your PC and if so, what apps will you use. For example, if you are using Outlook for e-mail on your PC or laptop, do you want to have the ability to sync with your PC. This way, both databases are identical.
    How many contacts would you have? (Personal, business or both)
    The PDA should be a mirror image of the PC (IMO)
    I have one that I sync to Outlook for personal use. When I go away, I just grab the PDA and all my addresses, phone numbers and e-mails are in my pocket.
    Michael ;)
    NORTH of 60°
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    Early, you have a PM.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • Early B.
    edited July 2005
    Right now I'm merely interested in knowing which operating system is better. My main purpose will be to store Word files. I used to own a Dell Axim and din't treally use most of its features. Just wondering if Palm OS works better, in general.
  • faster100
    faster100 Posts: 6,124
    edited July 2005
    palm Os works fine for just word/excel... the windows based handhelds are way overpriced if you just plan to use word... my wife started with a tungsten E, and now also has a zire 72 and loves it. has word, real player to play mp3's.. does excel, and a bunch of other stuff.. color screen
    were thinking of selling ours to get the new palm life drive......
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2005
    Pocket PC gets my vote. I've owned both, and it's more intuitive for me.
  • brettw22
    brettw22 Posts: 7,623
    edited July 2005
    I would definitely NOT recommend the Life Drive........
    The appeal of the 4GB HD is trumped by the fact that the thing is only running with 64MB of memory and EVERY time you want to open an application, you will be waiting 1-3 seconds for it to populate. If you don't think that's a long time, sit at a store with it for 30 minutes and go through the apps to see how you like it.
    Even though the T5 has 55MB of operating memory, it's much faster since it's not hunting for everything on the harddrive and instead from the flash memory.
    If Palm upgrades the operating memory to 256, I'll look at the LifeDrive at that point.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited July 2005
    I have been very impressed with my PPC (Dell Axim X30). There are tons and tons of great apps available for PPC to make it a must have device.
    I've owned both PPC and Palm and I highly prefer PPC.
