Should I Buy?
carney115
carney115 Posts: 32
edited August 2005 in Car Subwoofer Talk
I found a open box special at a local store for a Rockford fosgate P3 12 inch sub. Its selling for $115. The reason why its an open box special is because the concealment ring is cracked. This is the metal ring running around the outside edge of the sub. I'd like to know what everyones thoughts are on this. I have a polk DX12 now. Should i buy the RF p3?
Kevin
Post edited by carney115 on
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    If it's at a retail store that will still negotiate a little, offer them $80 for it. They will want to move that sub quicky since its damaged. They may or may not reduce it further, but it's worth the try.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • carney115
    carney115 Posts: 32
    edited July 2005
    Yea, i'll try that. Is a cracked concealment ring a big deal? will it affect the sound quality?
    Kevin
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    It'll make it harder to create an airtight seal, but you should be able to fix it with some type of epoxy or the like, I would think anyways. I haven't seen the crack.
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2005
    sealing a sub to a box with epoxy = mucho bad... good luck getting it back out of the box :). sealing the sub itself is a different matter... perhaps post a high-res photo?
  • carney115
    carney115 Posts: 32
    edited July 2005
    New question - I just came across another great deal for two 10 inch JL w3's with box included. If it came down to it, i was wondering what everyone would choose........one 12 inch rockford fosgate p3 sub or two 10 inch jl w3's (keeping in mind that i have a kenwood amp which when bridged runs 460 x 1 rms or 230 x 2 rms ) Let me know what you guys think
    Kevin
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2005
    Id take the W3's over the Rockfords but Id take the Momo subs over the W3's. In their price range theyre the best you can get.
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited July 2005
    While I've never heard the P3's, or listened extensivly to the Momo's, I am currently running to 10" W3's, and not too blown away by them. They sound ok, nothing special, they can get pretty loud though. Judging from polk's reputation, I'd say go with them. The DX sub you have will be hard to beat.
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • carney115
    carney115 Posts: 32
    edited July 2005
    what kind of amp and rms you got running to the w3's?
    Kevin
  • carney115
    carney115 Posts: 32
    edited July 2005
    Do the momo's really sound that good?, i always thought that jl's were the top of the line
    Kevin
  • neomagus00
    edited July 2005
    the jl W7 is often considered to be the reference for subwoofers, but you can't really pick a single reference... some subs are designed only to sound really good, some only to get really loud, some are made with a bit of both... i'd say the w7 is a good reference in that last category, but there are definitely better-sounding subs, and most certainly louder ones out there...
    i'd also consider diamond, eclipse, and adire, amongst others, to be TOTL
  • carney115
    carney115 Posts: 32
    edited July 2005
    if you had to choose between a rockford p3, jl w3, and polk momo which would you choose?
    Kevin
  • neomagus00
    edited July 2005
    i would personally choose the polk. what i think you should do is hunt down a dealer that has at least two of those three and listen to them all, for a long time, and pick the one you like the best, because your ears aren't the same as mine.
    for example, i find many subs to be very annoying - i can hear a buzz in addition to the tone, which most people can't hear, so i demand a sub that has an ultra-smooth suspension... you may prefer a different style
  • exalted512
    exalted512 Posts: 10,734
    edited July 2005
    JLs are at the top of the price range, not the top of the line...its 2 very different things. you will not go wrong with polk
    -Cody
  • carney115
    carney115 Posts: 32
    edited July 2005
    well the thing is that someone i know is selling 2 10 inch jlw3's with the box included for a real cheap price. I figured this would be an upgrade from my one 12 inch Polk DX sub. I figured this would be more efficient seeing that i'm currently overpowering my polk dx by about 60 extra watts
    Kevin
  • neomagus00
    edited July 2005
    well, take a listen to that setup, then listen to the other setups you're looking at (or as close to them as you can get), then make your decision... hearing it is what it all really comes down to
  • swerve
    swerve Posts: 1,862
    edited July 2005
    RE8!!!!
    cats.vans.bag...
  • neomagus00
    edited July 2005
    i like my re8, but i think any of these three will outperform it... ooh, shot down... :)
  • carney115
    carney115 Posts: 32
    edited July 2005
    whats a RE8?
    Kevin
  • neomagus00
    edited July 2005
    resonant engineering's RE8, their smallest and lowest-end sub, but a remarkable performer nonetheless... i use one for my dorm system, it's quite nice... it even managed to keep up with four bookshelf speakers in a large lounge room when we had a party there, it's good stuff...
  • spwuinmk67
    edited July 2005
    Right now, the amp I have on my Jl's is the same one you see for sale in my sig. It was running bridged to the DX in there as well, but i wanted a little more output. The one worked fine in my car, but not what i wanted in my truck.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • MacLeod
    edited July 2005
    Id take a Momo sub over most any sub costing under $400.
    Youd have to get into the W6, W7, IDMAX territory before you outdo a Momo.
    Ive been to Tweeter several times listening and comparing these subs to Alpine, Eclipse, JL, MB Quart, Kicker and the Momo is outstanding. Very smooth sounding. Not the hardest hitting but the best sounding.
  • exalted512
    edited July 2005
    actually, id take the IDQ over the momo but whos counting...
    -Cody
  • MacLeod
    edited July 2005
    Cant argue with that. The IDQ is a pretty sweet sub.
    It does have an advantage over the Polks cause it works in a much smaller box which makes installation a little easier. But it cant handle as much power and I trust the Polk's build quality a little more.
  • carney115
    carney115 Posts: 32
    edited July 2005
    Is the momo sub a big improvement from the DX or are they pretty similar sounding? I have a dx now and i don't know if its worth it to buy a momo
    Kevin
  • neomagus00
    edited July 2005
    it's a personal choice - if you feel that the momo sub sounds better enough to justify the money spent, by all means do it - we can't tell you that.
  • carney115
    carney115 Posts: 32
    edited July 2005
    well in your opinion, if you have heard both the momo and the dx, do you think the momo is a big improvement? Just trying to get some insight
    Kevin
  • carney115
    carney115 Posts: 32
    edited July 2005
    I'm also havin a tough time finding a momo at a retail store in the massachusetts area. I can only find it online. Anyone from mass know of a store that sells polk momo's?
    Kevin
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    I didn't mean putting epoxy between the sub and the enclosure:rolleyes: . I meant fixing the crack in the retainer/concealment ring.
  • MacLeod
    edited July 2005
    Tweeter and Fryes are the only retail stores that sell the Momo line I believe.
    Ordering online isnt a problem as long as you stick to an authorized dealer. Crutchfield.com is the more reputable. They are huge with the full backing of the manufacturers and they have an outstanding reputation for honesty and customer service. The downside is theyre not any cheaper than retail.
    Sounddomain.com is my favorite. They are almost as big as Crutchfield and have a great reputation as well. Plus theyre a good bit cheaper than retail. Ive ordered from them before and had no problem.
    And my personal opinion is the Momo sub is Polks best sub yet.
  • exalted512
    edited July 2005
    key word being yet;)
    -Cody
