RTi 100 mid an upper problem
ckdahl
I have a pair of RTi100's which seem to have lost their upper end. I replaced the tweeters and it sounds like they improved so I pulled the midrange's and inspected, but all appears well. Is there a way to check crossovers or just replace the mid's as well?Or if the tweeters were blown would it make sense the mid's would go as well? Driven by Deneon 2802 if that matters. Thanks for any advice
Post edited by ckdahl on
Hello,
The best way to check out the driver is to swap it for the driver in the other enclosure. If there's no sound, then the driver has been damaged and you would send it to Polk Audio, 2550 Britannia Blvd., Suite A, San Diego, CA. 92154. Please inlcude a short note giving us your name, address and a copy of your sales receipt.
Regards, Ken
