SDA serial number list
ND13
ND13 Posts: 7,601
edited March 2014 in Vintage Speakers
Someone posted an SDA list of serial numbers and I can't seem to find it anymore. I had printed it off and have lost it. I checked the serial numbers on my SDA 2?s and if the list was correct I would have the 2As not the 2Bs. I believe the 2B's serial numbers started in the 14000s and my serial numbers are in the 12000s. Can anyone help with the serial number issue?
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
Post edited by ND13 on
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    That's the one. Thanks alot. I was correct about the 2Bs starting in the 14k's.
    One more question, though, If my serial numbers start in the 12000s, do I then have 2As? They have SL2000s and BB IC.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited July 2005
    If you have ONE tweeter, you have 2b's. That chart is for SDA's that you can use the AI-1 with, I think.
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    Oh, so your saying that the chart is only telling which 2B's are compatible with the AI-1?
  • RuSsMaN
    edited July 2005
    Yes.
  • hoosier21
    hoosier21 Posts: 4,408
    edited July 2005
    Don't forget at Troy's house when we looked at the manual for the AI-1, it had some blurb about the AI-1 not working with some 2B models, at least not without a modification to the crossover.
    Jesse, can you scan that manual?
    Russ
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 49,834
    edited July 2005
    Done
  • ambiophonics
    ambiophonics Posts: 722
    edited March 2014
    A buddy if mine is looking at some SDA-2's and trying to figure out if they are 2Bs. Is the list posted by F1NUT confirmed as reliable or should my friend ask the seller to pull a driver or the passive to inspect the crossover? The cabinets are the old vinyl type, one tweeter, not sure on the IC connection. What do you think?
    2 Channel - Polk SDA-2BTL, Carver TFM-35, Peachtree iDAC, Qobuz streamed via Episode Lynk using bubble UPnP server
  • westmassguy
    westmassguy Posts: 6,850
    edited March 2014
    Some early 2Bs had blade/blade sockets. 2B studio monitors look almost identical to the 2As. Your friend needs to pull one of the passive radiators to see if the crossover is the one piece, rectangular 4th generation, or the two piece 3rd generation.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Schurkey
    Schurkey Posts: 2,100
    edited March 2014
    The posted list from F1nut was accurate AT THE TIME IT WAS PUBLISHED. The blurb about "ALL UNITS of 2B..." meant "all units" that had been built at that date. Later units were fully-compatible.
    The "modification" to make them AI-1 compatible is nothing more than a foot of wire to connect the second blade of the blade/blade socket to the negative binding post, and some sort of adapter to make the pin-blade AI-1 cable plug into the speaker--possibly by replacing the blade/blade socket with a pin/blade socket. Now, it'd be easier and better to use an additional regular binding post, or a "Speakon" connector, or some other connection method--in part because the aftermarket AI-1 probably doesn't use a pin-blade connector.
    http://www.polkaudio.com/forums/showthread.php?131691-2B-and-EARLY-1C-AI-1-modifications
    F1nut Posts: 49,834
    edited March 2014
    That list is 100% accurate today as it was then, you read it wrong.
  • Schurkey
    edited March 2014
    I read it that "ALL UNITS of SDA 2B require plug adapters and some internal modification..." but in fact there are 2Bs which, ACCORDING TO POLK SCHEMATICS already have the proper pin/blade SDA socket on the back, and it's already got both conductors wired appropriately to be compatible with an AI-1.
    Therefore, some time AFTER the list was published, Polk started equipping SDA 2Bs with the correct sockets and wiring. Therefore "ALL" units of 2Bs do NOT require plug adapters and internal mods. Early units do, later units don't. The list was correct at the time it was published, but is no longer correct for the later-production 2Bs.
    The exact same thing happened with the 1C, early units needed the "Plug adapters" and the "internal modification", later units didn't. The only difference is that the change from non-compatible to compatible happened before that list was published, and Polk supplied the serial numbers of the early, non-compatible 1Cs.
    F1nut Posts: 49,834
    edited March 2014
    No, what it says is that all 2B's prior to the serial numbers listed on the chart require plug adapters and internal modification. The serial numbers listed for the 2B's on the chart do not require plug adapters and internal modification as they are already set up with the pin/blade connections and mods.
    It also says that all 1C's prior to the serial numbers listed in addition to the serial numbers noted at the bottom need the plug adapters and internal modification.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited March 2014
    I don't know if this helps but my #s are 15673 left-15439 right blade/blade w/ dates of late 1987 and early 1988 and think 3rd generation. I might be wrong on generation but I also have the fabric sided solid light oak tops that were restained.
    http://s42.photobucket.com/user/leftwinger57leftwinger/media/speakers001_zpsf58960fb.jpg.html
  • westmassguy
    edited March 2014
    Lew, yours are 4th generation
