HTR-5790/Lsi9
mtbmarsh
mtbmarsh Posts: 1
Well I've been searching through this forum and cannot seem to get a clear answer....
I just bought an HTR-5790 for real, real cheap. I'd like to buy Lsi9...will this reciever even drive the speakers a little bit, how loud?
If I need to purchase a separate amp, what kind of power and price range am I looking at??
Thanks, I'm definately new to the home theater thing!
R
Post edited by mtbmarsh on
  • MSALLA
    MSALLA Posts: 1,602
    edited July 2005
    If you search this fourm, you will find alot of talk on this subject.
    LSi 's are 4ohm speakers.The HTR will drive them but it will most likley over haet with the volume only at a moderate level.
    More than watts for the amp, I would look for something that is 4ohm stable.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • aaharvel
    aaharvel Posts: 4,489
    edited July 2005
    Hi MtBMarsh- welcome to the forums. =)
    The simple answer to your question is no. For a 4ohm LSI-9 (even 6ohm LSI-7's) setup, your Yamaha does not have the necessary current to drive LSI9's beyond an 'adequate' level. And if I were you, don't take the "110x7" very seriously. With all channels driven simultaenously throughout the 20hz-20khz region- it's more like half that number.
    Use the Yamaha's pre-outs so you can hook up an additional dedicated amplifier. From a value standpoint, Outlaw and Adcom come to mind. Remember, more speakers are ruined by underpowering them more than overpowering them; and your new Yamaha will make one KICK-**** pre-amplifier. Hope this helps.
    AH
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • John K.
    John K. Posts: 822
    edited July 2005
    MT, your 5790, if it's still in good condition, has a quite powerful amplification section, essentially identical to the 1400. Tests of the Yamahas have shown output into 4ohms on the order of 150 watts. The 5790 is THX certified and one of the requirements of that certification is driving a 3.6 ohm load to reference level(quite loud)in a 2,000 cubic foot room, so it should drive the LSi -9 more than just a "little bit". If it turns out that for your room and listening level you want more, you can add a separate amp in the future, but you shouldn't assume at this point that it'll be needed.
  • mantis
    mantis Posts: 17,570
    edited July 2005
    Maybe I'm crazy but why do so many people want to buy sub par receviers for great speakers???
    If your shopping for Lsi then your shopping for a higher standard. Lsi speakers are designed for audiophiles who want more then your average speaker quallity. They are designed to go the extra mile is sonic perfection. Why would you want to power them with something thats not on the same level???
    I'll never get it. Why Why Why??????
    Dan
    O and Yamaha to boot........ man just shoot me now.
    Dan
  • aaharvel
    edited July 2005
    (BANG!)
    and +1
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • nellis8166
    nellis8166 Posts: 292
    edited July 2005
    I was in a similar situation a couple of years back after I bought my LSi9s. The answer is simple most ordinary run of the mill recv. will not feed the LSI series the way they need to be fed. I spent 1k on an Adcom and it is the best investment I ever made. The difference is staggering. The LSI's are amazing speakers. You can run them on nominal power but I would venture a guess that you will be dissapointed. Hope this helps.
    RTi10
    CSi5
    RTi28
    SVS PB12-ISD2
    Denon 2106(pre/pro)
    Adcom 5503(200x3)
    Audioquest Diamondback ICS
    Kimber Kable 8tc biwire(mains and center)
    "Don't let your silly dreams fall in between the crack of the bed and the wall."
    -J. James
  • TroyD
    TroyD Posts: 13,124
    edited July 2005
    Will it run them? Sure. Over the long haul, not good for your receiver though.
    You will not be hearing what they are capable of........knuckle under for the amp as well.
    BDT
  • aaharvel
    edited July 2005
    Hey nice 7400. I have the 5300 and 7300 powering my rti- gig.
    how much watts does the 7400 put out in 8 and 4ohms? again nice amp.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • nellis8166
    edited July 2005
    Thanks, it is a very nice amp for the money, wouldn't give it up for anything. I think it puts out approx 125wpc into 8 ohms and 250 into 4 ohms. It's not a huge amount of power but you have to remember that it is clean, undistorted power which is just as important.
    RTi10
    CSi5
    RTi28
    SVS PB12-ISD2
    Denon 2106(pre/pro)
    Adcom 5503(200x3)
    -J. James
  • aaharvel
    edited July 2005
    del.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
