Installation Question
jb604
jb604 Posts: 1
Hi. I have just bought a pair of RTi4 , and two pairs of R15 bookshelf speakers. However, the only speaker stand I could find was at a local ikea store.
The speakers are a bit heavy for the stands and the velcro that comes with the stands may not hold the speakers in place properly and may not be stable enough. The top of the stands have 3 holes that can be screwed to the bottom of each speaker for better support and stability.
Is it safe to screw the stand to the bottom of the each speaker or will I damage the speakers?
Thank you in advance,
JB
Post edited by jb604 on
  • mantis
    mantis Posts: 17,331
    edited July 2005
    Return these stands. They are not good for your speakers. Don't put screws into your speakers.
    Any kind of Wall mount or speaker stand that requires you to damage your speakers are no good in my book.
    head over to your local Tweeter for better stands. Ikea is a nice store but not for audio and video furniture. Cd or dvd holders are ok.
    Dan
    Dan
  • Mike682
    Mike682 Posts: 2,074
    edited July 2005
    Originally posted by jb604
    Is it safe to screw the stand to the bottom of the each speaker or will I damage the speakers?JB
    No way...you can ruin your speakers.
    Go to an electronics store and look for stands that are meant to hold bookshelf speakers. These stands are more robust and can handle the extra weight of bookshelves.
    Check here:
    http://shop.polkaudio.com/ProductListing.aspx?cid=228
    Mike
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • unc2701
    unc2701 Posts: 3,587
    edited July 2005
    Best buy carries sanus speaker stands. No ultimate foundations- just the lower end, but they are pretty solid for the price.
    Backburner:Krell KAV-300i
