Best CD Changer
MxStYlEpOlKmAn
Whats the best cd changer for under 300 dollars?
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
Sony.Dan
specifically, I would look for at least a 20 bit DAC (preferably 24)....Digital output is always nice as is a carousel type changer. Denon also is one that I would look at.
What is DAC? Why can you tell if a CD player will sound good?
The Marantz CC4000 may be available for that price. It comes w/a 3-yr warranty if purchased from an authorized dealer. I have no idea if it's the best in its price range. Just mentioning it as an option. The CC3000 is the same machine but w/out a headphone jack.Testing
Testing
Testing -
I always think the best CD player is a single CD player, not changer, changer is paint on the a** and sometimes it's so painful to deal with the transport, delay and noise and greater risk of mechanical break down.
I'm back again, Troy...:) -
What is DAC?
Boston speak for dick. Get one with at least 24 bits. -
DAC is a Digital Analog Converter.It takes digital in converts it to analog.Dan
The higher the bits the better? (24+)
