Adam's ride
Yeah, youll be the first one to own the P9 and no you dont have to buy the EQ.
As for sub placement, experiement. There isnt a set rule.
And there isnt anything really wrong with your new sub, Polk subs are just that good!
If I had to guess Id say the wide and narrow crap is the curve of the crossover. So you could cross it at 80 Hz and then adjust the curve to either narrow (24 db) or wide (6 db).polkaudio sound quality competitor since 2005
It gets real low and all shakes all my interior... but nothing flexes hard besides the backseats. But like some songs should really beat that aren't.
Like you listen to ludacris all the time it'd be a great setup... but that i don't.cats.vans.bag... -
Youve also got to consider break in time. A sub isnt going to sound its best right out of the box. Itll take a while for it to break in properly then it may cut loose.
Or it may not be all its cracked up to be. Shoulda stuck with the Polks!
heh. yup! nah i'm sure i'll get it right. and i am highly skeptical to begin with. as for what's wrong with the alpine... it just isn't what i want anymore i think as well.Originally posted by MacLeod
what do i do about occasional turn on/turn off pop?cats.vans.bag... -
Learn to live with it.polkaudio sound quality competitor since 2005
no way...? you've got to be joking.Originally posted by MacLeod
my mom is going to have a hard time justifying 800 dollars for a cd player... lol
does it hook up traditionally?cats.vans.bag... -
without getting the eq, i dont think it would be worth it to get the p9, unless you planned on getting it in the future. If not, go with the 960mp or 9600mp. I had the 960, and its got more features then you will ever need1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
I'm sure I'll get it in the future. I seem to acquire things rather quickly... lolOriginally posted by spwuinmk67
-adamcats.vans.bag... -
The pop is because of timing. Different brands of gear have different delay cycles for powering down/up.
When you first power up an amp, the flow of current suddenly flowing into the amp is not stable and so your amplifier dutifully reporduces this inrush as a THUMP. Same thing when you power it down.
Your Alpine has a "soft start" so that when you turn it on it starts out with the volume at 0 and then moves it up to the level it was at before you turned it off. However, it doesnt have one for when you turn it off.
You can build your own timer circuit but I dont have the foggiest idea of how to.polkaudio sound quality competitor since 2005
bleh my car picks it up good... I think i'm missing alot of mids lol.
on my way home i found out i can go lots further with the volume knob than 24. simply because I tuned it at 34.... no clipping or anything so that's good. i get it up to about 27 and i can't bear some of the bass. like i said i am just being very skeptical.
oh yea... i stopped at my INsurance agent and put 5000 dollars worth of protection on my ****... and I think i'm getting the p9cats.vans.bag... -
The curve is actually the parametric equalizer. Slope is what crossovers use...Originally posted by MacLeod
If I had to guess Id say the wide and narrow crap is the curve of the crossover. So you could cross it at 80 Hz and then adjust the curve to either narrow (24 db) or wide (6 db).http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
Slope, curve, slanty line.
You say tomato, I say tomato.polkaudio sound quality competitor since 2005
I wasn't picking on you, for onceOriginally posted by MacLeod
I was just clarifying the difference. Adam mentioned a "curve", which refers to Alpine's built-in parametric equalizer. http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
not talking about my alpine though.Originally posted by AustinKP
hehcats.vans.bag... -
Yea - a little update... ever since I figured I tuned it when the HU was on 27 volume... the sub is great.
the ride home i listened to Tech N9ne - Anghellic all the way up and by the time I got home I was getting short of breath...
so i think it's alright....
lol
