LSi7 - Naked !!!!!
Got in my LSi7's last friday and was trying to decide where to mount them. The WAF was pretty low mounting anything larger than the RM series speakers I have now as surrounds.
I decided it had to be done and decided to try and pull off the wood sides from the LSi's I just got to make for a slimmer profile mounting them to the wall. (I am currently planning to use the wall bracket built into the lsi7)
I have called Polk CS before about this and they thought it would work if I used a wide implment to pry it off with and took my time. The person I spoke with then thought they would still sound very good (like LSi's should) even with the wood removed. (it is still 3/4 mdf with internal bracing - I figure that is all most subwoofers have so I shouldn't have much resonance problems from a 5-1/4 woofer crossed over at 80hz)
I called Polk CS again just before I started to pull it off to get their reassurances again before I start and spoke with a different CS rep. The story I got this time was the old series (what I have) used double sided tape to attach the wood, the new series uses glue and the sides will not come off. Even though I have the old series, he still STRONGLY recommended that I not try to remove the sides as he has seen the finish pulled off the speaker due to the strength of the tape used.
So much for assurances - Since I will not be able to mount these to the walls in their current state without alot of greif from the wife, I decided to forge ahead. I wrapped a 3" putty knife in an old t-shirt (now shredded) and started to work the putty knife into the corner of the side/speaker. I felt it give way and started working the putty knife around the speaker working it in about 1/4 inch to help loosen the hold of the tape.
When I got back to my starting corner, I pushed the putty knife inabout 1" and pulled it back out. (part of the shirt stuck and tore under the wood) I worked the knife in and out about 2/3 of the way around the speaker before the side was loose enough to just pull away.
The entire side is gloss black as i had hoped. There are no holes in the sides (also as I had hoped)
I worked off the other side the same way and cleaned up the mess. I will post some pics when I get home from work tonight, but let me say, Polk should offer these without sides as an option for surround mounting. It looks absolutely fantastic all in gloss black with the slimmer profile.
More with pics later - I have to get back to work.....
Michael.
Michael.
I seem to remember someone having pics of the BIG LSi's naked at some point....
Ah yes, gotta love the search feature :
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=27613If you will it, dude, it is no dream. -
Thanks for the link to the naked 15's. That is actually what got me thinking about doing this, but I could not find the post again.....
Here is after removing one side....Mains.............Polk LSi15 (Cherry)
Here are the tools I used. (at this point side one is done, and side 2 is under way.) I ended up not using the wide putty knife. My 3" one is pretty flexable a more rigid knife would have been handy....Mains.............Polk LSi15 (Cherry)
Here they are side by side. (I have not done the second channel yet - I did not have time) I think the slimmer profile looks great. (keep in mind this is for a surround to mount to the wall....)Mains.............Polk LSi15 (Cherry)
McLoki,
I don't think you will like the sound with them mounted using the built in keyhole. I had my RT25i mounted like that and the bass was dull/hollow. I now have them mounted using some Btech BT77 mounts.
Link here
Look at my showcase to see what they look like with some Polks mounted. They will allow you to angle/swivel if needed, plus they hold them firmly from the bottom and are SOLID!!! I use a little bluetak to isolate them further. They sound night and day different.See profile for rigs. Nothing else here. -
Can you show pics without the grll?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Here is the single speaker.Mains.............Polk LSi15 (Cherry)
Here they are side-by-side.Mains.............Polk LSi15 (Cherry)
So in the end, was it worth it? It doesn't look like you saved that much space to me...
Keep in mind they are not mounted yet (will post pics when they are) but yes, I think it was worth it. It took an 8.5" wide speaker and made it 7" wide - a savings of about 22%.
For my mounting locations, that will make a big difference. (plus I like the slimmer gloss look for the surrounds)
I was careful taking the sides off so I can always remount them if I want to at some point in the future. I think they will stand out a little less than they would have otherwise (the wife requirement) and I am sure the sound will blow away the RM series I was using.
looks like a win/win and I can always go back to the way they were if I want to.
Michael
(BTW - all marks in the pics are either flash or fingerprints - that gloss is gonna be a **** to keep clean. (glad they are being mounted high...))Mains.............Polk LSi15 (Cherry)
Originally posted by billbillw
McLoki,
Link here
Thanks for the tip. I will look into purchasing a set if I decide I do not like the sound the way they are mounted.
A few questions for you though:
How far out into the room do the BT77's extend the speakers (over mounting them with the keyhole)?
Does the arm that comes out from the wall move or just the plate that the speakers are mounted to?
About how far below the plate does the mount extend? (from the bottom of the speaker, how much of the mount can you see?)
I am thinking about using these as mounts for my fronts as well as my surrounds. (when I post pics of my setup, you will understand....)
Thanks for the great tip. I will keep you all posted what I end up doing. (will have to do something because my right surround has to be angled in about 15-20 degrees)
Any scratches on the glossy side while you were taking out the wood panels?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Does the arm that comes out from the wall move or just the plate that the speakers are mounted to? Maybe 3", not sure exactly though. It depends how you center the speaker on the base/grip. The arm is fixed, the base swivels/tilts.
About how far below the plate does the mount extend? (from the bottom of the speaker, how much of the mount can you see?) Approx 5" total
Michael
By the way, I thought the LSi7 were you mains. Here you are talking like they are your surrounds. Are they going to be both? Did you look at my showcase? That should give you a good idea since the LSi7 are similar in size to my RT25i. Good luck. Just don't let your wife totally hamstring you on mounting these. You need a little freedom.See profile for rigs. Nothing else here. -
I have been using LSi7's as my mains and I just purchased another set for my surrounds. I purchased them used for a good price just because I was planning to remove the side panels (and wasn't sure it would work). The new set is the ones I was planning to mount on the walls, but if it works out, I may do the same with my fronts. Right now they are not in the best of positions.
For WAF - I just wanted to get them in the room first, then I will worry about better mounting setups..
JoeyV - Glad to say both the speakers and side panels are still in good shape. No scratches at all. The finish must be more durable that I was giving it credit for.
Before - After = Reduction
8.5 - 7 = 1.5
Savings/Original = % Reduced from Original
1.5/8 = 17.65%
Or, you could say the new speaker is 82.35% of the original's width.
It should be 1.5/8.5 there, smarty.
It was a typo. The math is right though 1.5/8.5 = 17.65%See profile for rigs. Nothing else here. -
LSi's look better naked. Night and day difference, not even the same speaker anymore really- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I like the side panels and I like them naked... its a mixed bag for me.
BUT.... I'm glad you got the panels out and you like it this way... TWO THUMBS UP!!
Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I like them better with the cherry wood, but it is nice that there are options. At some point I would like to make a pair of maple LSi's.
Kinda like a properly displayed thong............
As long as what's underneath has a nice fit and finish, I can take it either way.:)HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
i prefer a smooth glossy finish on whats under thongs as well....
BillW. Just wanted to say thanks for the tip on the speaker stands from Crutchfield. I finally got them in and installed and they look and work great.
Here is a final picture of my right speaker and you can see why 1.5" in speaker width made such a difference in the speaker working for me or not....
Thanks again,
Thanks again,
Michael
That's cool. I'm glad they worked for you. Someone (Whadyasay) recommended them to me back in March when I was looking for something similar. They are definetly one of the most robust, yet attractive designs out there. They will firmly hold any bookshelf without the need for drilling holes.See profile for rigs. Nothing else here. -
SEXY!!! WOOT!!!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
And well done! If I was the wife I would definately approve!
CathyMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I like the look without the side panels on. Nice workDan
+1..
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Or if you prefer actual input:
Very interesting. Sure is neat you knowing you can take the side panels off; almost like personalization. They sure do look like totally different speakers without them, but they still look just as good as before. Can't decide which I'd prefer.
Looks great in your set-up, McLoki. Congrats!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Its a good thing your handy, because those could have been ruined easily if not so gingerly.. That gloss seemed real sensitive to marks when i had my lsi7's.. and if you spend 4 -5 hundred on a set or more retail.. you may be scared to try the removal... But they do look cool.. I liked the side panels myself thoughMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
