Whats Next
mantismantis Posts: 15,943
edited June 2002 in Forum Testing Area
NOW THERE'S A PRATICE POST..........WHAT??
OK I WILL PRACTICE TALKING TO KNOWBODY.
CAN YOU HEAR ME.........YES I CAN.............HOW ARE YOU?..........VERY FINE I THANK YOU.........CAN YOU TYPE?.........NO I CAN'T...........IS THIS STUPID?.........YES IT IS........I ASSUME YOU DON'T CARE FOR THIS.............NO SIR I DON'T.............THINGS CHANGE................DON'T FIX WHATS NOT BROKENOW LETS TRY SOME COLOR
HOW ABOUT A QUOTE
AND BOLD LETTERS
Dan
Post edited by mantis on
  • BBUBBABBUBBA Posts: 66
    edited April 2002
    Agreed , don't like this new format.:mad: :confused: :eek: :mad:
  • rnoseworthyrnoseworthy Posts: 41
    edited April 2002
    mantis,
    Have you ever thought about adding a second 6 1/2 mid woofer to you 1000's? like on the 800's.
  • RuSsMaNRuSsMaN Posts: 17,995
    edited April 2002
    Hello, McFly????
    Bueller? Bueller?
    Test area, every 'good' forum has em.... test your sig, test posting pics......
    It aint THX certified, but it'll work!!!
    Cheers,
    Jaime Jugnootenberg
  • goingganzogoingganzo Posts: 2,797
    edited April 2002
    testing 1 2 3 testing i agree i think we should go back to the old style i have to go and liik for the new posts instead of having just 3 spots
  • gidrahgidrah Posts: 3,036
    edited April 2002
    Nope: Testing concludes that GG still can't spell;):D
    I've been busy (at the hardware store:eek:) this last week or so. I kinda like it. My categories wouldn't be the same. Current Polks, Polk of old, etc.
    Make it Funky! :)
  • mantismantis Posts: 15,943
    edited April 2002
    rnoseworhty,
    have I ever considered a second 61/2 driver for the 1000's?
    No ,i feel this speaker is more balanced then the rt800 series.The single 61/2 driver I feel sound's great at any volume.It's also sealed .
    Adding another 6 1/2 driver I don't think would help the 1000 in any way.I think it's fine the way it is.Even the low extention has a quick and clean sound,I got mine to sound like passive speaker's.
    If you want to inprove the sound of the rt1000 series, run them with better amp's ,wire,and placement.Keeping the sub amp down low is also away to improve them.Mine sit about 9 oclock.They blend in with the rest of the speaker there setup in my room.
    If you go listen to the rt2000 series they dont need a second 6 /2 driver.They perform extremly well the way they are.The amount of driver in a speaker doesn't always equal better or worse sound.Balance is key.Most of the time...LESS IS MORE!!
    Dan
    edited April 2002
    doesnt the second driver in the RT800 help to get the bass output , Where the RT1000 has a sub to do that?:confused:
    I also like the smooth tightness of the RT1000 as it is:p
    edited April 2002
    i can spell but i am not the best and plus i am not the best at typeing when i type ip papers i have spell check i guess i just suck and have no brains just that i am not a great speller i dont care but yess i am a bad speller and typest just wish they had spell check on here
  • sgtgtosgtgto Posts: 310
    edited April 2002
    Hi GG:
    You could buy a dictionary!:D
    Gary
    edited April 2002
    As long as I can understand it, I don't care if you use E-bonics, hooked on phonics or hooked on blunt chronics. As long as I can get the jist.
    Make it Funky! :)
  • sntnsupermen131sntnsupermen131 Posts: 1,831
    edited April 2002
    hey did i do this quote thing right...
    edited April 2002
    alright i got this technology thing down...
  • cruiser3cruiser3 Posts: 47
    edited May 2002
    Tesssting!!
    Onkyo 696 receiver, Panasonic DVD RV31U,Polk RM6600 w/ 350 sub (rti28's 2nd zone), JVC Dual tape deck, MMF-2.1 Turntable, JVC 5010 CD R. ((its simple, its cheap, it works))
  • hlalannehlalanne Posts: 183
    edited May 2002
    testing 1 2 3
    testing 1 2 3
    testing 1 2 3
    seems to be working
    Wooden Delight Theater
    9/11
    NEVER Forget !!!
  • begbiebegbie Posts: 630
    edited May 2002
    testing 1 2 3
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Polk fx500i -side surrounds
    Polk rc60i -rear surrounds
    Onkyo TX-NR 1009 (9.2) receiver
    Velodyne cht12
    Polk psw111
  • OskaromOskarom Posts: 9
    edited May 2002
    Originally posted by begbie
    testing 1 2 3
    just testing
    never used this befor but always wanted to test it :D
    Best Regards
    Oskar Omarsson.-
    My HT
  • cgravilcgravil Posts: 101
    edited June 2002
    <Taps Mic... a short feedback howl> Hi my name is Clay and I'm a Polk-aholic.......
    The probibility of someone watching you is directly related to the stupidity of the action in question.:eek:
    edited June 2002
    :supermad: :party: :beer:
  • Ron-PRon-P Spaceman Spiff Posts: 8,511
    edited June 2002
    Did everyone see the size of Russ's head?
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
    edited June 2002
    Jeez man, wait for final confirmation tonight.... pics and all....
    Cheers,
    Russ
    edited June 2002
    No NO NO We don't need pics....please.
    Peace Out~:D
    If...
    edited June 2002
    Aww cmon man, you don't want to see the 8th wonder of the world?
    -Russ
    edited June 2002
    check it out
    9/11
    NEVER Forget !!!
Howdy, Stranger!
