I'm Back...with my new fiberglass sub enclosure!
yep, i know, jest messin witchaOriginally posted by swerve
i was being a moron... no need to get technical... this is the friend who marked the tweeter and midbass wires wrong.... i then proceeded to basically re-rewire... yea good times
-adamIt's not good, very fundamentally simply not good. - geolemon
Originally posted by Vr3MxStyler2k3
Sound Deadener in a sub enclosure is a good thing, especially a sealed one...
It will help cancel out the backwave, it also helps the enclsoure dampen the rattles. I am a fan of foam pads that line the enclosure myself... good stuff...
And yes, dont put a woofer in a sealed enclosure that just had caulk put in it
Make sure you put some type of foam tape around the cut out hole...
What kind of damping? Would Dynamat be ok inside the box?polkaudio sound quality competitor since 2005
Something like this would be the best
http://www.secondskinaudio.com/products/specials_detail.php?productid=4
its sole intention is to absorb sound waves.
That stuff might dampen vibrations but it dosnt do what foam does...
For instance, stick your head inside your subwoofer enclosure and talk... it will echo and sound bassy...
Ok, now imagine what they enclosure is adding to your bass (or detracting from). That is probally adding alot of bloom. Not counting if you have a ported sub, alot of that backwave is exited out the port, YUCK...
Foam pads dampen the vibrations + cancel out any backwave and gets rid of that nasty "bloom"/echo inside the enclosure, especially makes a difference in ported enclosures, IMO
I like this stuff...
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&DID=7&CATID=29&ObjectGroup_ID=137&filter=sonic&raid=44&rak=sonic_barrier
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
its a closed cell foam...
Go secondskin!!! yay.... their foam rules all mwuahahacats.vans.bag...
I don't think it helps that much when your sub box is located in a trunk.
any little bit helps, cause eventually all those little bits add up into something significantIt's not good, very fundamentally simply not good. - geolemon
I'm finally done.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
...http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
and the wide view.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
I also posted a video at www.realmofexcursion.com under the Ascendant Audio section. It should be up by tomorrow.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Looks good bro. Youre all set.
Ill be sure to check out the video when its up.polkaudio sound quality competitor since 2005
weak!!! you need to get a test tone cd. enclosure looks good:)
looks great. i beg to differ... he doesn't need a test tone cd...Originally posted by exalted512
-Cody
lolcats.vans.bag... -
ascendant atlas 12Music is like candy, you have to get rid of the rappers to enjoy it
you know, I do have a test tone CD. I have just the song to play on it. It is a test tone from 0-100 Hz. It REALLY makes the sub move. I'll have to try it...
Alpine 9815
The video is now available herehttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
The **** has like barely any excursion it seems. I have it to where I can tolerate and it looks like it's not even trying. lol. guess I got a little headroom just in case.Originally posted by AustinKP
i'll get a video and some pictures as well. realmofexcursion has files and test tones too I believe.cats.vans.bag... -
I got my $4 grille in today. Here's a couple pics. I just have to figure out how I'm going to attach the thing now...
Alpine 9815
I might end up painting it. What do you guys think? Leave it like it is? This pic shows how much clearance I have. It should allow for plenty of excursion with no problems.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
