New here and liking what I see ;-)
Jim Wy
Jim Wy Posts: 64
Being a Polk newbie I just happened upon this forum while trying to find info on my new PSW10 sub and a used pair of RTi28s and CS175i ctr that I picked up this week. Just for clarification let me tell you my search itinerary for the last week...
avsforum.com and audioholics.com for a week trying to get opinions on smaller subs and bookshelf speakers for the sole (90%+) purpose of watching movies on my new 50" Panny DLP and getting nowhere (helpful opinions but very dispersed) with most replying "just go out and buy a HK 635 and a pair of $$$peaker$ and you should be fine". Apparently my "All I want is good quality at 90 dB and don't NEED 108 dB to freak the cat out" didn't come through loud enough.
Came here, found MY sub, MY mains and MY centre, found out how old they were and what they're worth, and am now very happy with my purchase.
That being said... how does one go about getting a grill for a used CS175i or at the very least the little "polkaudio" insignia if I can make my own grill... I actually prefer to make my own, that way I can bend it slightly to look like my psw10 grill
JW
PS Still trying to figure out which is better- RCA Sub out to the left line in of my sub or left-right speaker level thru the sub and out to my mains. Opinions from Polksters would be greatly appreciated :D
link to my receiver (don't laugh)
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4153_33452_tab=B,00.html?compName=PNA_ProductDetailComponent
TV-_______Panasonic 50DL54
Receiver-__H/K AVR 330
Speakers-__RTi28s
Center-____CS245
Sub-______PSW10 (x2)
Surrounds-_FX300i's
Post edited by Jim Wy on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2005
    Hit the "service and parts" tab on the top center of this page.
    BTW, welcome to CP, hang out here long enough and you will find that you really should have gotten the bigger setup that can blow you out of your listening room.
    It isn't that you don't need it, it is simply the fact that you can do it.:) :)
  • Jim Wy
    Jim Wy Posts: 64
    edited June 2005
    Tell me about it;) Had to stick with the WAF a bit tho... next step 28s to the back and RTi8s in front
    Also edited a bit while you were replying. Haven't bought the wiring yet, RCA or thru-put? I can go either way. (that didn't come out right)
    TIA
    JW
    Speakers-__RTi28s
    Center-____CS245
    Surrounds-_FX300i's
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2005
    Use the sub out.
    On the receiver, set sub on, crossover to 80, all speakers to small. This will utilize your receivers power more efficiently and clean up your midrange.
    Regards,
    PolkThug
  • Dennis Gardner
    edited June 2005
    RCA or throughput? That has been a fight with Polk for years. Only your ears can tell you what works best.
    I started my HT quest with a Polk 5400 sat system years ago and went through alot of variations, 25s, 55s, 70s and finally settled with vintage SDAs.
    The search is most of the fun, as long as sanity is present.
    Enjoy!:D
  • dorokusai
    dorokusai Posts: 25,640
    edited June 2005
    The aforementioned forums are worthless for Polk support, you have come to the right place.
  • opus
    opus Posts: 1,252
    edited June 2005
    Wy,
    Welcome to Club Polk. Spend your time here and you will find a wealth of information, edited and policed by the "polksperts".
    And in my humble opinion;
    never apologize for your current gear, Enjoy what you have, don't try an keep up with the Jone's and upgrade if you can/must
    regards......kevin
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • louthewiz
    louthewiz Posts: 581
    edited June 2005
    dorokusai is so right, The newbies over at avs forum think they know it all and in fact they can learn alot from this forum here.
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
