I'm Back...with my new fiberglass sub enclosure!
AustinKP
Hey guys, I've been in MO for a week for my brother's wedding. I just spent 1.5 hours reading all the posts that I missed. In the meantime, I was able to finish my fiberglass sub enclosure. It's kinda side/upfiring. It's quite a bit louder in my trunk than in my back seat, though it still is just as clean as it has been. I'll have pics when I get home from work today.
-Austin
-Austin
http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2
Alpine 9815
Post edited by AustinKP on
honestly, dont start a thread like this unless you have the pics;)
Im curious to see a side/up firing sub!
Eh, it's more diagonal-ish. Closer to side-firing, but aimed up a tad. Anyway, I finally was able to get some pics. Please excuse my filthy car. I just got back from a 2500-mile road trip, part of which was on gravel roads. I haven't had time to wash it yet.Originally posted by MacLeod
Alpine 9815
2 Gallons SecondSkin Spectrum V.2 -
The sub is flush-mounted. You'll notice the front isn't round but more ovalish with flattened ends. This was to give me somewhere to mount the grill I'm going to get from partexpress.comhttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Here you can see my amp rack that I made. Standing up, you can't even see it. I moved it there from the back of my rear seat. I'm trying to maximize my usable trunk space.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Here is the front view. I installed some screw-down terminals that also accept banana clips for quick release. The terminals are really great because they only require small holes and are easy to make sure they're sealed. The terminal cups I got from BB or CC sucked. One of them leaked air, even though they weren't supposed to. I got these little terminals from Radio Shak.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
nice....cant wait till i get mine done been working on it for a few months now should be ready to go in and paint the main box part and then start working on the outer finish pieces i want bass this summer dangit been without for about a monthSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
The "air bubbles" that you can see on the left side are just gaps between the fleece and the fiberglass where the fleece puckered a bit. All the layers of fiberglass are firmly sandwiched together. This box is very strong. I can easily stand on it without it bending at all.
Oh, and on a side note, fiberglass random weave mat SUCKS! It is way too stiff and rigid to work around anything more than a slight bend. It frays too much to leave a smooth surface, requiring piles of bondo or hours of sanding. It sucks up way too much resin. I'll never build anything with it again.
After the first layer and a half, I switched to fiberglass cloth weave. MUCH easier to work with, drapes 100x better, and doesn't suck up nearly as much resin. It doesn't lay up as thick so you have to do more layers, but it's well worth it.
The cloth weave ends up being quicker to use since you don't have to mess with trying to make it stay in place like you have to do with the mat. Plus, since it takes less resin, it ends up being a lot cheaper. Even though the cloth is more expensive per sq ft. than the mat, the resin is much more expensive than both.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Look sharp Austin...is that a Mustang btw? It looks like it from the tail lights, but im not sure...1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
I've never seen a sub mounted in moldy cheese before. Cool!
my thought exactly then i realized it ain't colored yetOriginally posted by PolkThug
I've never seen a sub mounted in moldy cheese before. Cool!cats.vans.bag... -
nice workIt's not good, very fundamentally simply not good. - geolemon
Yeah, I figured I'd try something a little different this time. Plain ol' fiberglass is just so cliche'. Moldy cheese just really brings out the clarity that fiberglass doesn't offer. The softer cheese box gives a richer, deeper bass that I loveOriginally posted by PolkThug
Spwuinmk - yes, it's a mustang.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Thats cool bro. It looks like it was in there stock (except for the moldy cheese thing).polkaudio sound quality competitor since 2005
Austin thank you for posting this picture... my buddy has a stratus and I suggested him glassing something like that in a similar location.... he seemed to like the idea since it would still allow for alot of trunk space.
anyways that post 1k for adam
-adamcats.vans.bag... -
Here are a couple pictures of how I finished my trunk. After getting the thickness I wanted with the Spectrum, I had a lot of brush lines and stuff. I decided to spray my trunk lid with the same rubberized undercoating stuff that I used for my MM6 fiberglass pods. It looks a lot better and a lot smoother than just the spectrum alone.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Plus, it'll match my sub box when I finally finish it.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
here's a closeup of the terminals that I used. You can get them herehttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
so before I painted it this morning, I decided to try the ol' water test... CRAP! I could hear an air leak when I pushed on the cone, but the dang thing leaks like a sieve in a couple places. I'll have to put on another layer or two in certain spots. This would have all been done a week ago if I hadn't started with that dang fiberglass mat. :mad:http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
lesson learn'd, then... for me, i mean
haha...if you have leaks id put at least 3 more layers...
I just did this morning. 2 layers on the minor leaks, and 3 on the problem areas. Should be in ship shape by the time I get home from work. It was kinda cold this morning so I mixed the resin a little hot.Originally posted by exalted512
-Cody
BTW, I've heard of this being done, but I wonder if it's actually effective: Does spraying sound deadener inside a fiberglass box have any benefit?http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
why not?Originally posted by swerve
don't do that......http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
yah, why not, i figured i'd do that to my midpods...It's not good, very fundamentally simply not good. - geolemon
i heard that doing that is very bad and it messes everything up including the sub magnet and even the air waves it emits.... my friend told me this... the same friend who helped me hookup my components.. so it's vary reliable infurmaeshun...
ah, your friend may have been thinking of the icky fumes some products give off as they dry, which can and will melt certain materials found in the construction of some speakers... which is why you don't put your sub in a box you've sealed with caulk for at least 2 days...
and the entire point of the stuff is to mess with the airwaves the sub emits
i was being a moron... no need to get technical... this is the friend who marked the tweeter and midbass wires wrong.... i then proceeded to basically re-rewire... yea good timesOriginally posted by neomagus00
Sound Deadener in a sub enclosure is a good thing, especially a sealed one...
It will help cancel out the backwave, it also helps the enclsoure dampen the rattles. I am a fan of foam pads that line the enclosure myself... good stuff...
And yes, dont put a woofer in a sealed enclosure that just had caulk put in it
Make sure you put some type of foam tape around the cut out hole...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
