Mystery Karma
1235
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited May 2005
    Apluys? Jesus. Hooked on Phonics man. I'll start a freakin collection for you.
    Oh, Oh, Can I change mine? WAAAAA! :D
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2005
    Laughed out loud, literally.
    Thanks Bob!!!
  • TroyD
    TroyD Posts: 13,124
    edited May 2005
    In.
    From Ron-P
    Russ, I ALWAYS use an ****-gasket. Never hover because of splash down and back splatter. I also float landing pad made from TP for a soft landing to avoid the above. One can never be too cautious when dealing with the general public.
    You can find the original thread here:
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=4365&highlight=wash
    I dunno about the funniest, but it's right up there.
    BDT
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2005
    ...and from that same thread.
    pairs? WAAAAAAAAAAAAAAAAAA
    You fat illiterate ****!!!!!!
    Classic past-Polk. What happend to those days? Good-times, good-times.
    If...
    Ron loves a film = don't even rent.
  • dragon1952
    dragon1952 Posts: 4,907
    edited May 2005
    I unfortunately forgot this rule the other day. I just know I'm gonna come down with AIDS or something. I think I felt my immune system die immediately :(
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2005
    Well, if there is no TP, or you forget to build your TP landing pad, while your ripping out the center of the ****-gasket you can use that as an emergency landing pad. A little less resistance to heavy loads compared to TP but it'll absorb the blunt force of the first drop. Of course, remember, that the center of the ****-gasket will not hold up to strong wind gusts or payloads released under severe pressure.
    By all means, never ride the public porcelain pony bare back.
    If...
  • Skynut
    Skynut Posts: 2,967
    edited May 2005
    Wow yall took this thread somewhere I never expected.
    What a visual.:eek:
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Shizelbs
    Shizelbs Posts: 7,433
    edited May 2005
    Sez Russ;
    "He's been instructed to remove his pantaloons Maurice.
    He won't be shitting his flat hat, he's going to mess his chair."
    And I'm in.
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2005
    fine here is my quote
    The Ganzo Decoder Ring Version 1
    This was sent to me and I thought of Ganzo...hehe
    http://ryanross.net/leet/
  • LiquidSound
    LiquidSound Posts: 1,261
    edited May 2005
    One of the funniest things I've ever read. Period.
    Posted by shack in a thread about cable burn in.
    quote:
    Originally posted by gmorris
    Lets all just get along for a hot minute and assume that cable burn-in is real. This would mean that all cables burn-in. So, that would mean if you hooked up your rig with lamp cord, the lamp cord would eventually burn-in, and make the rig sound better.
    This comment got me to thinking. Could there really be burn-in for lamp cords? And if so, what better to test it on than…..LAMPS. We bought a pair for our living room a couple of months ago and I swear that the one we have used the most is much brighter now. It is right next to the chair where we usually sit when we read so it gets used a lot and the other one is on a table and rarely gets turned on. One is obviously burned-in and the other is not…an ideal situation to see if lamp cord burn-in phenomenon exists. I enlisted my wife to help with the experiment.
    First we tried the double blind test. My wife and I both put on blindfolds and she would turn the lamp on and off I would try to tell which one was brighter and vice versa. No definitive conclusion here. With the blindfolds on we really couldn’t even tell if the lamps were on or off.
    Next I remembered that several folks felt that some pre test evaluation was necessary to help recognize the differences during the test. My wife and I both did some critical looking at the lamp (sans shade) for several minutes to better familiarize ourselves with each one. Again, no real conclusion here. The spots made telling the difference a little difficult (they have finally gone away). And thanks for all of the well wishes for my wife. The eye doctor says her eyesight should be 90% as soon as the patches come off and there will only be slight permanent damage to the retinas.
    Well, as you can see the testing for lamp cord burn-in was generally inconclusive. I will say that I CAN tell a noticeable difference between the brightness of the 2 lamps with the burned-in one being much brighter. I’m sure there are computer programs that could be utilized here….but all I can say is “Trust Your Eyes”.
    **EDIT** – Never mind. I just found out my daughter put in a 100 watt bulb in the reading lamp and the other has a 75 watt bulb. I think this may alter the findings somewhat.
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
    "If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
  • dragon1952
    edited May 2005
    LOL! Yes...I'd forgot about that one. Priceless!!! :D
  • Toxis
    Toxis Posts: 5,116
    edited May 2005
    And the winner is???????????????
    *pick me, pick me, pick me*
    :p:p:p
  • Skynut
    Skynut Posts: 2,967
    edited May 2005
    Isn't it midnight somewhere yet?
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • michael_w
    michael_w Posts: 2,813
    edited May 2005
    Past midnight here :p ... damn mystery has been keeping me wondering for a while now hehe
  • Frank Z
    Frank Z Posts: 5,860
    edited May 2005
    It's all part of the mystery folks.:)
  • faster100
    faster100 Posts: 6,124
    edited May 2005
    the participation was the surprise :D karma's over LOL
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • LiquidSound
    edited May 2005
    Faster is correct! The gift was bringing us all together!
    Not buying it? Ok, ok..picking of the winner..on. I'll get started.
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
  • LiquidSound
    edited May 2005
    *drum roll please*
    Ladies and gentleman, the winner is!...
    The twice Karma lucky..... nadams!!
    He is the proud new owner of two, full and flawless sets of Martin Logan Standard Energy Transfer Coupler Spikes (8 in total)link *now you see why I had the requirements...*
    They should be shipped monday. I hope you enjoy. Thanks to everyone that participated in the Mystery Karma..we had quite a bit of fun doing it.
    P.S. Send me your addy in PM nadams.
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
  • janmike
    janmike Posts: 6,146
    edited May 2005
    Nice Karma. Congrats nadams.
    Michael ;)
    NORTH of 60°
  • RuSsMaN
    edited May 2005
    Wow. Outstanding offer LS, outstanding.
  • Tide
    Tide Posts: 154
    edited May 2005
    Nice job LiquidSound. This thread was very entertaining.
    Congrats nadams.
    SDA 2s; HSU STF-2; Yamaha RX-V1
    SDA-CRSs; Polk PSW-303; Rotel RB-960BX; Rotel RSP-960AX;
    LSi 7s; Infinity PS8; Rotel RB-980BX; Rotel RSP-980
    Mirage Nanosat 5.1; Yamaha RX-V2300
    Monitor 5s, 5 jrs, & 4s
  • bobman1235
    bobman1235 Posts: 10,822
    edited May 2005
    Unfrotunately your link got chopped, here's the full :
    http://www.martinlogan.com/miva/merchant.mv?Screen=PROD&Product_Code=KSPIKE8&Category_Code=acces
    Congrats nadams. :)
  • TroyD
    TroyD Posts: 13,124
    edited May 2005
    Way cool, congrats!
    BDT
  • Frank Z
    edited May 2005
    LS,
    Very Generous dude!! Congrates to the bast...
    lucky winner.;)
  • Shizelbs
    edited May 2005
    Wow, very generous.
  • Skynut
    Skynut Posts: 2,967
    edited May 2005
    Way kool karma. Good karma to you LS
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • Toxis
    Toxis Posts: 5,116
    edited May 2005
    Damn that's a nice karma... Those would've come in handy. SIGH! hahaha
    Congrats (again you ****) nadams. :D:p
  • michael_w
    edited May 2005
    Congrats on the nice karma. Not at all what I was expecting though.
  • madmax
    madmax Posts: 12,434
    edited May 2005
    Very nice! Good karma follows giving karma. Thanks for the chance on it!
    madmax
    Vinyl, the final frontier...
  • madmax
    edited May 2005
    Given all the hassle now would be a good time to offer a karma for those newer posters who couldn't participate. Maybe those with less than 170 posts. :)
    madmax
