Dusty drivers
ND13
ND13 Posts: 7,601
edited June 2005 in Vintage Speakers
Does anyone have any suggestions on how to safely remove a little dust from the drivers in my Mon 10A's? They are still tacky and since I'm having to replace one of them, I don't want them to look different.
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
Post edited by ND13 on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited May 2005
    Windex and soft cotton cloth - windex goes on cloth not cone.
  • danger boy
    danger boy Posts: 15,722
    edited May 2005
    i was always curious. why the mid drivers are tacky in the first place.. anyone know the reason behind that? and they attract dust like no ones business.
    PolkFest 2012, who's going>?
  • ND13
    ND13 Posts: 7,601
    edited May 2005
    No way, that's just to damn simple. I figured someone would have some elaborate cleaning technique or some miracle concoction.
  • Spawndn72
    Spawndn72 Posts: 453
    edited May 2005
    It is to simple..
    1) You will need some asbestos. I realize it is illegal to own or use, but come on you are serious about your audio aren't you? Now get out there and find some!
    2) You will need some chess cloth. And I mean cheese cloth, don't go get cheese cloth thinking I mispelled it. Chess cloth is significantly harder to find, but it is well worth it.
    3) You will need a staging area and a cleaning area and a cleaned area. See suplimental instruction sheet #1002a for the setup of each of these areas.
    4) You need an industrial grade high pressure washer. 5000psi should do the trick. What you want to be careful of though is having "to much" pressure. 4999psi is to little and 5000.000001psi is to much. Make sure you get a "good" pressure washer.
    5) Now as to what to do with all this stuff, I don't have a clue, this was all the info I could find out in my searches. The true answer lies somewhere in the sahara dessert. The government has done a very good job in keeping this info a secret but with Harrison Ford AND Nicolas Cage's help I think we can track it down.
    This message will self destruct.....
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
  • ND13
    ND13 Posts: 7,601
    edited May 2005
    Sure it's not in AREA 51?
  • ND13
    ND13 Posts: 7,601
    edited May 2005
    Maybe all the distortion sticks to mids so we won't hear it.
  • BlueMDPicker
    edited May 2005
    Someone must have swapped your drivers with some out of an SDA - Sticky Driver Anomaly
  • pmlewis
    pmlewis Posts: 100
    edited May 2005
    Dusty Driver seems like a cool name. What occupation would he/she have?
    A. Local radio personality.
    B. Small town porno actor.
    C. Rural UPS delivery driver.
    D. All of the above.
    SCompRacer Posts: 8,363
    edited May 2005
    I had a busty driver at the old house. UPS had trouble getting a shirt that would fit her properly. Used to order stuff just to watch her deliver it.:D
  • michael_w
    michael_w Posts: 2,813
    edited May 2005
    I am curious about this too. My mon 7Cs have cat hair stuck to them from the previous owner. Are you sure windex is safe to put on the drivers with a cloth?... I wouldn't want to mess anything up.
  • Polk65
    Polk65 Posts: 1,405
    edited June 2005
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    Now I've gotta make some grills, just put in the replacement driver Polk sent me and it doesn't match in appearance. Anyone know why they sent a 6503 instead of a 6500?
  • Polk65
    Polk65 Posts: 1,405
    edited June 2005
    MW65xx Series Consolidation 10-03-2004
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=22514
    "The MW65xx line is being consolidated into three drivers: MW6502, MW6503, MW6510".
    They have probably run out of stock of MW6500's, but give CS a call to be sure.
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    The only difference I've been able to notice, besides appearance, between the 6500 and the 6503, is that when I did the pressure test(gently pushing in the PR) the new driver doesn't have as much travel. Should this change with break-in? Sonically I haven't noticed any difference. Both of the Mon 10A's have very tight enclosures. It would probably take several minutes for the drivers to recede while holding in the PR. I assume this is what you would want, correct?
