Mystery Karma
Apluys? Jesus. Hooked on Phonics man. I'll start a freakin collection for you.
Oh, Oh, Can I change mine? WAAAAA!
There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
Laughed out loud, literally.
Thanks Bob!!!Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
In.
From Ron-PRuss, I ALWAYS use an ****-gasket. Never hover because of splash down and back splatter. I also float landing pad made from TP for a soft landing to avoid the above. One can never be too cautious when dealing with the general public.
You can find the original thread here:
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=4365&highlight=wash
I dunno about the funniest, but it's right up there.
...and from that same thread.pairs? WAAAAAAAAAAAAAAAAAA
You fat illiterate ****!!!!!!
Classic past-Polk. What happend to those days? Good-times, good-times.If...
Ron loves a film = don't even rent. -
I unfortunately forgot this rule the other day. I just know I'm gonna come down with AIDS or something. I think I felt my immune system die immediately
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Well, if there is no TP, or you forget to build your TP landing pad, while your ripping out the center of the ****-gasket you can use that as an emergency landing pad. A little less resistance to heavy loads compared to TP but it'll absorb the blunt force of the first drop. Of course, remember, that the center of the ****-gasket will not hold up to strong wind gusts or payloads released under severe pressure.
By all means, never ride the public porcelain pony bare back.If...
Wow yall took this thread somewhere I never expected.
What a visual.:eek:Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Sez Russ;
"He's been instructed to remove his pantaloons Maurice.
He won't be shitting his flat hat, he's going to mess his chair."
And I'm in. -
fine here is my quoteThe Ganzo Decoder Ring Version 1
This was sent to me and I thought of Ganzo...hehe
http://ryanross.net/leet/ -
One of the funniest things I've ever read. Period.
Posted by shack in a thread about cable burn in.
quote:
Originally posted by gmorris
Lets all just get along for a hot minute and assume that cable burn-in is real. This would mean that all cables burn-in. So, that would mean if you hooked up your rig with lamp cord, the lamp cord would eventually burn-in, and make the rig sound better.
This comment got me to thinking. Could there really be burn-in for lamp cords? And if so, what better to test it on than ..LAMPS. We bought a pair for our living room a couple of months ago and I swear that the one we have used the most is much brighter now. It is right next to the chair where we usually sit when we read so it gets used a lot and the other one is on a table and rarely gets turned on. One is obviously burned-in and the other is not an ideal situation to see if lamp cord burn-in phenomenon exists. I enlisted my wife to help with the experiment.
First we tried the double blind test. My wife and I both put on blindfolds and she would turn the lamp on and off I would try to tell which one was brighter and vice versa. No definitive conclusion here. With the blindfolds on we really couldnt even tell if the lamps were on or off.
Next I remembered that several folks felt that some pre test evaluation was necessary to help recognize the differences during the test. My wife and I both did some critical looking at the lamp (sans shade) for several minutes to better familiarize ourselves with each one. Again, no real conclusion here. The spots made telling the difference a little difficult (they have finally gone away). And thanks for all of the well wishes for my wife. The eye doctor says her eyesight should be 90% as soon as the patches come off and there will only be slight permanent damage to the retinas.
Well, as you can see the testing for lamp cord burn-in was generally inconclusive. I will say that I CAN tell a noticeable difference between the brightness of the 2 lamps with the burned-in one being much brighter. Im sure there are computer programs that could be utilized here .but all I can say is Trust Your Eyes.
**EDIT** Never mind. I just found out my daughter put in a 100 watt bulb in the reading lamp and the other has a 75 watt bulb. I think this may alter the findings somewhat.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend -
LOL! Yes...I'd forgot about that one. Priceless!!!
And the winner is???????????????
*pick me, pick me, pick me*
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Isn't it midnight somewhere yet?Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Past midnight here
... damn mystery has been keeping me wondering for a while now hehe -
It's all part of the mystery folks.:)
the participation was the surprise
karma's over LOL MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Faster is correct! The gift was bringing us all together!
Not buying it? Ok, ok..picking of the winner..on. I'll get started.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
*drum roll please*
Ladies and gentleman, the winner is!...
The twice Karma lucky..... nadams!!
He is the proud new owner of two, full and flawless sets of Martin Logan Standard Energy Transfer Coupler Spikes (8 in total)link *now you see why I had the requirements...*
They should be shipped monday. I hope you enjoy. Thanks to everyone that participated in the Mystery Karma..we had quite a bit of fun doing it.
P.S. Send me your addy in PM nadams.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Nice Karma. Congrats nadams.Michael
NORTH of 60° -
Wow. Outstanding offer LS, outstanding.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Nice job LiquidSound. This thread was very entertaining.
Congrats nadams.SDA 2s; HSU STF-2; Yamaha RX-V1
SDA-CRSs; Polk PSW-303; Rotel RB-960BX; Rotel RSP-960AX;
LSi 7s; Infinity PS8; Rotel RB-980BX; Rotel RSP-980
Mirage Nanosat 5.1; Yamaha RX-V2300
Monitor 5s, 5 jrs, & 4s -
Unfrotunately your link got chopped, here's the full :
http://www.martinlogan.com/miva/merchant.mv?Screen=PROD&Product_Code=KSPIKE8&Category_Code=acces
Congrats nadams.
If you will it, dude, it is no dream. -
LS,
Very Generous dude!! Congrates to the bast...
lucky winner.;) -
Wow, very generous.
Way kool karma. Good karma to you LSSkynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Damn that's a nice karma... Those would've come in handy. SIGH! hahaha
Congrats (again you ****) nadams.
Congrats on the nice karma. Not at all what I was expecting though.
Very nice! Good karma follows giving karma. Thanks for the chance on it!
Given all the hassle now would be a good time to offer a karma for those newer posters who couldn't participate. Maybe those with less than 170 posts.
