materials check list
JDMCivicB16B
JDMCivicB16B Posts: 67
edited August 2005 in Custom Fabrication
I was able to find a place to buy resin and filler..
Fiberglass resin w/ Hardener
Mat & cloth
Rage Gold Filler
Painters Tape
Acetone
Any other materials i will need? I plan on doing a fiberglass enclosure in the spare wheel well in my civic.
'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
(the wife's new ride)
..new project..wife comes first before s2k
Post edited by JDMCivicB16B on
  • neomagus00
    neomagus00 Posts: 3,899
    edited March 2005
    sandpaper of varying grits... you can get a package that has a couple sheets of a few ratings from very coarse to very fine, that will do quite well. you also need a paintbrush or three.
  • exalted512
    exalted512 Posts: 10,735
    edited March 2005
    did you buy extra hardener or just the one that came with it? if not, buy extra, its like 2 bucks a tube. also, like neo said, PAINTBRUSHES. i LOVE the ones from Home Depot. I think they have the wooden handles but dont quote me. theyre extremely cheap but are VERY good. i tried other brushes and they sucked ****.
    youll need an old pair of scissors (that still cut decent)
    if youre sanding, youll DEF. need latex gloves...DO NOT DO IT WITHOUT IT. if not, then theyre not necessary unless you dont like to get your hands dirty...
    i also used blue solo cups to mix the resin in. DO NOT GET THE CLEAR ONES...they suck really bad...the red ones are fine too i would assume.
    youll also need some sort of scale to measure how much resin (in oz.)
    what exactly are you fiberglassing? if youre putting mdf on top and just fiberglassing the inside then theres no need for filler or sanding if it wont be seen...or if youre covering it with carpet or vinyl it wont be really necessary...you might need a little with vinyl, but def. not with carpet
    -Cody
  • JDMCivicB16B
    edited March 2005
    thanks..
    I plan on fiberglassing the area of the wheel well..then when it hardens..im thinking 3 or 4 coats. ima put it out..ima use dowels to mount the sub rings, and build a wooden mount for the 2 amps, then..i have figure out what to do then..im guess carpet and fiberglass again..and then sand, paint..and ima put a plexiglass covering on that will be flush with the trunk floor.
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • exalted512
    edited March 2005
    buy a mouse sander...they are your friend...
    -Cody
  • JDMCivicB16B
    edited March 2005
    how many coats you think i should use?
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • JDMCivicB16B
    edited March 2005
    also..i heard since its only around 40-50 degrees in NY..i would have to use more hardener? is this true?
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • exalted512
    edited March 2005
    i used 7 on mine. yes, since its colder youll need to mix it hotter. (mixing it hotter means adding more hardener). hardener is also referred to as a catalyst.
    -Cody
  • JDMCivicB16B
    edited March 2005
    i bought 3 gal of resin..is this enough ?
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • exalted512
    edited March 2005
    umm, how many gallons is one of the big cans from Home Depot?...lol
    -Cody
  • JDMCivicB16B
    edited March 2005
    i ordered from online from the company Bondo. its like 12 bucks a gal.
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • audiobliss
    audiobliss Posts: 12,518
    edited April 2005
    JDMCivicB16B - How's this project coming? You've got me interested in it, now; fill me in! lol Have you started yet? What's it looking like?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • JDMCivicB16B
    edited April 2005
    hey, I am still mid-way thru. I have done the mold, now i am custom making a enclosure for the sub and amp, that will go on the fiberglass mold foundation. i will take pics soon, just waiting for my fiance to give me back my digital cam.
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • audiobliss
    edited April 2005
    Awesome. Keep us posted!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • JDMCivicB16B
    edited April 2005
    Audiobliss, I read your little quote. I use to go offroading myself, now my Infiniti QX4 stays on the pavement. Me and my father rebuilt a 1945 army jeep, and its tons of fun for offroading! Saw your pics of the jeep, looks nice and clean. I see that you are working on the audio system. If you need a sub box, I have one for sale sitting in my garage, brand new. 2 PolkMOMO 12s Sealed box. if you have AIM, my sn is civic95vtec.
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • AustinKP
    AustinKP Posts: 861
    edited April 2005
    wow, that's a good price. What website did you get it from?
    -Austin
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • JDMCivicB16B
    edited April 2005
    FROM AMAZON.COM, Bondo company
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • wrxsoldier
    wrxsoldier Posts: 1
    edited August 2005
    when u are mixing the resin and the hardener civic whats the ratio that u mix it?
  • neomagus00
    edited August 2005
    whatever it says on the bottles... it depends on which resin and hardener you're using... mine, for example, is 1:4, but the same brand has 1:3 and 1:2 combinations, too...
  • audiobliss
    edited August 2005
    Yeah, I don't think I'd do any offroading in an Infinit QX4, either; I mean, I have a Cherokee and I don't! lol That army Jeep certainly sounds like a lot of fun!
    Your box has two Polk/MOMO 12s in it? I guess they'd be 2124s? Next time I see you on AIM and I have a minute, I'll IM ya about it. Probably won't work out, but I can try, lol.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
