materials check list
JDMCivicB16B
I was able to find a place to buy resin and filler..
Fiberglass resin w/ Hardener
Mat & cloth
Rage Gold Filler
Painters Tape
Acetone
Any other materials i will need? I plan on doing a fiberglass enclosure in the spare wheel well in my civic.
Mat & cloth
Rage Gold Filler
Painters Tape
Acetone
'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
(the wife's new ride)
..new project..wife comes first before s2k
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
Post edited by JDMCivicB16B on
sandpaper of varying grits... you can get a package that has a couple sheets of a few ratings from very coarse to very fine, that will do quite well. you also need a paintbrush or three.It's not good, very fundamentally simply not good. - geolemon
did you buy extra hardener or just the one that came with it? if not, buy extra, its like 2 bucks a tube. also, like neo said, PAINTBRUSHES. i LOVE the ones from Home Depot. I think they have the wooden handles but dont quote me. theyre extremely cheap but are VERY good. i tried other brushes and they sucked ****.
youll need an old pair of scissors (that still cut decent)
if youre sanding, youll DEF. need latex gloves...DO NOT DO IT WITHOUT IT. if not, then theyre not necessary unless you dont like to get your hands dirty...
i also used blue solo cups to mix the resin in. DO NOT GET THE CLEAR ONES...they suck really bad...the red ones are fine too i would assume.
youll also need some sort of scale to measure how much resin (in oz.)
what exactly are you fiberglassing? if youre putting mdf on top and just fiberglassing the inside then theres no need for filler or sanding if it wont be seen...or if youre covering it with carpet or vinyl it wont be really necessary...you might need a little with vinyl, but def. not with carpet
thanks..
I plan on fiberglassing the area of the wheel well..then when it hardens..im thinking 3 or 4 coats. ima put it out..ima use dowels to mount the sub rings, and build a wooden mount for the 2 amps, then..i have figure out what to do then..im guess carpet and fiberglass again..and then sand, paint..and ima put a plexiglass covering on that will be flush with the trunk floor.'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
..new project..wife comes first before s2k -
buy a mouse sander...they are your friend...
how many coats you think i should use?'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
also..i heard since its only around 40-50 degrees in NY..i would have to use more hardener? is this true?'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
i used 7 on mine. yes, since its colder youll need to mix it hotter. (mixing it hotter means adding more hardener). hardener is also referred to as a catalyst.
i bought 3 gal of resin..is this enough ?'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
umm, how many gallons is one of the big cans from Home Depot?...lol
i ordered from online from the company Bondo. its like 12 bucks a gal.'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
JDMCivicB16B - How's this project coming? You've got me interested in it, now; fill me in! lol Have you started yet? What's it looking like?George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
hey, I am still mid-way thru. I have done the mold, now i am custom making a enclosure for the sub and amp, that will go on the fiberglass mold foundation. i will take pics soon, just waiting for my fiance to give me back my digital cam.'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
Awesome. Keep us posted!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Audiobliss, I read your little quote. I use to go offroading myself, now my Infiniti QX4 stays on the pavement. Me and my father rebuilt a 1945 army jeep, and its tons of fun for offroading! Saw your pics of the jeep, looks nice and clean. I see that you are working on the audio system. If you need a sub box, I have one for sale sitting in my garage, brand new. 2 PolkMOMO 12s Sealed box. if you have AIM, my sn is civic95vtec.'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
-Austinhttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
FROM AMAZON.COM, Bondo company'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
when u are mixing the resin and the hardener civic whats the ratio that u mix it?
whatever it says on the bottles... it depends on which resin and hardener you're using... mine, for example, is 1:4, but the same brand has 1:3 and 1:2 combinations, too...It's not good, very fundamentally simply not good. - geolemon
JDMCivicB16B wrote:Audiobliss, I read your little quote. I use to go offroading myself, now my Infiniti QX4 stays on the pavement. Me and my father rebuilt a 1945 army jeep, and its tons of fun for offroading! Saw your pics of the jeep, looks nice and clean. I see that you are working on the audio system. If you need a sub box, I have one for sale sitting in my garage, brand new. 2 PolkMOMO 12s Sealed box. if you have AIM, my sn is civic95vtec.
Yeah, I don't think I'd do any offroading in an Infinit QX4, either; I mean, I have a Cherokee and I don't! lol That army Jeep certainly sounds like a lot of fun!
Your box has two Polk/MOMO 12s in it? I guess they'd be 2124s? Next time I see you on AIM and I have a minute, I'll IM ya about it. Probably won't work out, but I can try, lol.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
