Component Video input
VinnyP61
was wondering how to hook these up and is the pic better then S video ? Als what type of cables do i use thanks
Post edited by VinnyP61 on
Hi:
First your DVD and TV have to have component video out DVD, and in TV. Then you need to buy a component video cable set, about $70 or $80.00. Monster makes a good set of cables.
Yes, component is superior to s video.
Gary -
If you are hooking up a progressive scan DVD then component it your best choice.
By the way,
componet is the ONLY way to send a progressive scan Image to the monitor.
Componet is the superior cable in video except true RGB.
Really if your monitor is smaller than 36 inch you don't get the full benefits with componet video.S video is good under 36 and composite is also good under 36.There is a difference between s and composite.Its hard to see but with a trained eye,you can see the difference in edge detail and color correctness.Dan
So basically Vinny, if you don't have a trained eye, don't sweat it, use either one.
Cheers,
Russ,
do you know what a trained eye is?????no???I will tell you......Knowing what to look for in the images,seeing the detail of the edges,seeing the color as natural or bleeding.......ever hear of a company called ISF????
Ever think of posting nice things to say or do you enjoy all the negitive attention you bring to yourself?
Whatever.Dan
Hi Russ and Mantis:
Composit video uses one connecton for color blending and brightness. S video carries separate brightness and color portions whereas component connections take the concept one step farther by splitting the color signal into two parts and still one part brightness for greater accuracy and less color bleeding. Hence the need for three connections. Any tv will get a better picture with component setup.
If that were not true why have component connections on tvs and DVD players. Also the enhancement is not limited to tv size.
Use the component connections Vinny.
Gary -
Component Colors Pretty, S-video Bad.
Progressive Smooth, Interlaced Bad."The only way to get rid of a temptation is to yield to it." -
I guess I don't know what a trained eye is, but I'm sure you will tell me. Hopefully I can train my eyes, and watch for that edge detail, instead of the movie itself.
Thanks for the nfo Gary.
Cheers,
Hi Russ:
Thanks, just trying to be helpful.
Gary -
I noticed a difference right off on my XBR250 32" when I hooked up component video from the s-video . I see it in edge details as well as watching the the credits rolls . A black and white screen . Using a progressive scan you will see the scan lines disapear .
Even with my untrained eye balls I can see a difference in detail.The average Bubba ! -
Is the way to go. I have a 36" Sony Wega, Non HDTV, and a Sony Non-Progressive Scan DVD Player, and I could tell an great improvement over S-Video, and Composite Video. Go for it!
ps: B4 you go spending $100 for a Component Video Cable from MonsterCable (like I did) check out Frank Dai's Product at http://signalcable.com/video_cables.html -
yeah.....you can also pick up a standard AR cable for 40 bones or so. Well worth it regardless of the size of your TV.
Troy (of the Big Dumb Dions)I plan for the future. - F1Nut
