Good Surround Speaker Wire (12GA,10GA, Twisted wire etc)
malikarshad
malikarshad Posts: 527
I use Monster In-Wall CL3 14 gauge speaker wire for my surrounds. My length were 25 ft and 30 ft for surrounds
I re-arrangeed the wiring for my HT and my length has changed to 30ft and 50 ft. I had to patch the wire for my 50 ft length as I did not have contiguous length.
My question is should I switch to 12 GA speaker wire. I'm thinking of Sound King 12 GA or Carol 12 GA 4 conductor since my surrounds are biwired LSi7.
Or should I go 10GA.
I was looking for 12 GA twisted speaker wire on PartsExpress but could not find one.
Here are my choices in order of preference
1. 12 GA Twisted pair
2. 10 GA wire.(Does 10 GA make sense or 12 GA is good enough)
3. 12 GA 4 conductor wire
4. 12 GA 2 Soundking OFC copper wire.
Any other suggestions?
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
Post edited by malikarshad on
  • mantis
    mantis Posts: 17,629
    edited April 2005
    12 x 4 will be more then nessary for rears. If your running them in small which is what I would do, you can pull it off with 14 x 4 allday
    Dan
    Dan
  • malikarshad
    edited April 2005
    Dan I am worried about the length of 50 ft and 12 GA is recommended for that length. I'm using inwalls but the speaker wire are not outside so i don't necessarily need the CL3 certified wires. On the other hand I think the inwall are less prone to interference because of thick jacket around the wires.
    Do u know of a place where I can get the 12GA twisted wire?
    Dan what interconnects do you recommend? Currently I'm using an unknown brand NXG Banana plugs that I bought it off eBay a while ago. I don't like the crimp or solder type interconnect. I like the ones that are easy to connect and gives the most reliable contact.
  • PolkThug
    PolkThug Posts: 7,532
    edited April 2005
  • mantis
    edited April 2005
    14 guage is plenty for surround spekaers man. 12 guage is also fine. It's not that much more and worth the extra cost. Liberity and Beldon both make 12 x 4 conductor cl3 inwall speaker wire. Whenever you run inside the wall , cl3 is what you should use as per fire code.
    Interconnects? You mean speaker wire ends? For inwalls no connectors are needed. You simply use bare wire. there is no need to add connectors as Inwalls don't come out often. Most of the reason to use connectors on speaker wire is for easy removal. Use connectors at the amp end. The ones you have in the pic look fine. They look like Niles brand.
    Dan
    Dan
  • Willow
    Willow Posts: 11,325
    edited April 2005
    I use those for all my nanner plugs, and they work well and fit nice and tight. I did find every once in a while I have to check them to be sure they are tight
  • cnjvh
    cnjvh Posts: 253
    edited April 2005
    http://www.lenexpo-electronics.com/detail.php?m_id=184&price=2.49
    These have the most surface area I've seen and fit so tight I though they were the wrong size at first ;)
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • doggie750
    doggie750 Posts: 1,160
    edited April 2005
    It is believed that there is a issue regarding twisted wires vs the untwisted. Correct me if I am wrong, twisted is slightly - performance.
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
